I WANT TO SET UP THE TIME AND DAY - Computers & Internet
    Scholar:
  • 47 Answers
If you (double) click on the time on your computer screen, a new window pops up. Our Windows 7 version has a link in blue to change the time.
Depending on what software you're running, it should be pretty easy to move which bit is shown as "today" / "now". You may have a box to type in the time.
Posted on Mar 28, 2011
Lost manuel....how do I set the day and time....
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
Mar 29, 2011 | Radio Shack 3808 Digital Answering Machine
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
How to set time on the southwestern bell answer machine FA982B
I went to the southwesten bell freedom phone site on the web. Found answering machines.  My old machine was not listed, so I found instructions for a later machine.
The method for setting time was similar.  I tried it and it worked fine.
Your high prices prompted me to be less lazy.
Jun 10, 2009 | Southwestern Bell Lands Phones
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
What does set point time and set point temperature mean
set point time time when the set point temp activates
say i want my house to be 70 degrees while i sleep
i'll set the set point time to 11 when i go to bed, and the set point temp at 70
so to do what youwould like set the set point time for midnight and the thempature fore 55 or lowest seting with will keep the heater off. for the second time setting set point time at 5 am and set point tempature at desired temp
Jan 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Setting the day/time stamp on my answering machine
follow these steps carefully , see if that helps ya.
Dec 28, 2008 | Lands Phones
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
