Heating & Air, Trane XL 1100 not blowing heat, fan works but not hot, power was off for 48 hrs due to storm.
SOURCE: RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
Posted on Feb 15, 2009
SOURCE: Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
It is a problem on your low voltage side. I had the same issue and found that my wire going to my outside condeser had been snagged on a wire hanger in my basement and was shorting out the system. I went a head and replaced the entire wire from my outside unit to my indoor and haven't had an issue since. So my advice is go to HD or Lowes and purchase some 14 gauge wire and replace the low voltage wire. If that doesn't work, then replace the thermistat wire, and thermistat. Great time to upgrate to a energy efficient thermastat.
Posted on Mar 18, 2009
SOURCE: Ducted heating unit blows cold air and fan is always on..
that s correct the control is done by the thermostat stop the heating up to your set point and restart if the medium temp is under the set point
if this sequence fail means
- no power to the control element or is defective
thanks
Posted on Apr 27, 2009
SOURCE: Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Posted on Nov 08, 2009
  • 25 Answers
SOURCE: My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Posted on Mar 23, 2010
Trane XL 1100 igniter. What is the model number for the XL 1100
Please contact Trane customer service on this part number.
Dec 05, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
AC blows hot air
try this website fix & troubleshoot heating & A/C www.automedia.com and another car A/C repair www.directgardening.com
May 25, 2009 | 2002 GMC Envoy XL
Heating not working like it should
The fan for the A/C should blow harder than in heat. The fan should be on high for cool and low for heat. You can change the heat setting for medium but I would not recommend it because it may make heat coming out feel less.
Nov 21, 2008 | Heat Controller Thru-Wall/Window Air...
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
