Question about Pit SSR 110CC Pro Beginner Bike
Baja DR 50 will not start
I have a DR 50 kids field bike that was bought off eBay now the previous owner it uncovered for 5 years in his garden and he did not have the keys. Unfortunately, I removed the key barrel and threw it away and can't think what to do next, there are 2 orange wires a black and a red wire, how do I wire it to start it? The bike is electric start and pull start but the pull start is missing also he had been messing around with the wires and I have got most of the electrics working but I can never get the starter to work off the button when I press it the CDI buzzes but nothing else happens, the color wires that I am capable of attaching to the solenoid is thick red thick black with a wire coming from the inside of the engine itself and a yellow coming from the CDI. How do I wire it to start it electrically?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pit Master
  • 47,790 Answers
Hi, Kingoflords1 if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly then stall, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 2-3 years old when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and the battery needs to be replaced.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove and inspect your air cleaner paper elements that are not oil soaked can be cleaned with a soft brush and low pressure compressed air, oil soaked elements must be replaced. Gause mesh and foam elements can be cleaned by soaking them in a container big enough to completely cover them with a solution of 1 gallon of water and 1 oz. of Dawn dishwashing liquid for small and medium size elements, for monster size double the formula and let soak for at least one hour then rinse with warm water shake off excess and let air dry, "WARNING" do not use compressed air as this will embed micro-sized dirt and road grime and destroy the mesh pattern and stretch foam elements out of shape just squeeze it like a sponge and let air dry, use a fan if you're in a hurry. When completely dry spray a very fine mist of air filter oil evenly around the whole element.
6. Remove the carburetors, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove, clean, and inspect fuel and vacuum lines and replace as necessary.
8. Replace spark plugs with new ones and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ATV Connection
baja dr50 wiring diagram Google Search
http://www.bajamotorsports.com/system/documents/181_158_DR50_203_OM_eng_sp.pdf
http://www.bajamotorsports.com/files/parts_catalogs/Dirt%20Bike/DR50%20Hensim%20Dirt%20Runner%2049cc%20Dirt%20Bike%20(VIN%20PREFIX%20LLCH%20or%20LUAH).pdf
Baja Motorsports
Posted on Mar 18, 2017
2 Suggested Answers
  • 434 Answers
SOURCE: how do i wire up the starter control unit on a chinese DR50 engin
One of the big wires should go from the starter to the solenoid main poles. The other wire should go from the battery to the other main pole on the solenoid. The black should ground to the chassis, and the white should go to a push button start switch. The other pole on the start switch should be a fused 12volt positive wire. Hope thos helps...
Posted on Oct 14, 2009
Need to find out the year of this Baja mini-bike
Hi, Jimmy for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ID year of Baja Mini Bike DIY Go Kart Forum
MINI BIKE PICTURES
OldMiniBikes com
Baja Motorsports
Nov 03, 2016 | Electric Razor Pocket Rocket Scooter Mini...
My Baja 196cc takes off when I start it don't know why just that the bike was given to me recently, no manual
Hi, Jeff your mini bike has a centrifugal clutch and the previous owner may have tried to modify/bypass the governor for more speed if not done properly it will give you the undesired result which can be easily fixed by watching the video below I am sorry you can't find the first and best tool you ever bought for your Baja but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.Mini Bike Easy Governor Bypass 1080P
http://www.bajamotorsports.com/system/documents/86_OWNERS_MANUAL_-_WR65_Warrior_Mini_Bike_US_VIN_prefix_LUAH_.pdf
Mini Baja 6 5hp motor or other problems on 4Strokes com Forums
Jan 01, 2016 | Motorcycles
Mysql> desc contact_info -> ; --------------
Hi David,
It looks like you're missing two more null's in the third record, the column count is only 21 and you have 23 fields in your destination table.
All your data matches up to the columns, but you'll need to insert ", null, null" before the last paren to cover CompanyURL and companyPhone):
('Karson', 'B', 'Campbell', null, 'Dr.', 'Chief Resident', 'Pediatrics', 'kbc232@mvch.org', null, null, '585-544-1212', 'home', '1955-01-05', 'Wife: Molly Kids: Cassidy, Justine, and Cory.', 'Mountain View Hospital', null, null, null, null, null, null, null, null, null, null )
Sep 06, 2013 | Sun MySQL
Dio honda scooter
We can't help without knowing the model and year of the bike and the service history. If you haven't been looking after your bike it will have problems, Especially if you bought a secondhand bike and didn't check the service history before you bought it, or if you failed to service it before you used it. If you buy a used vehicle you should get it serviced properly immediately, this will highlight any defects that may have been hidden by the previous owner.
Aug 12, 2013 | Motorcycles
I bought a motorbike for R7000.00 with the logbook from the previous owner that signed of the motorbike. After he signed off the motorbike, there was about 4 to 5 new owners who bought the bike and nobody...
I would speak to someone in the department as to what you can do as there has to be some mechanism in the system to allow for your problem. It may be as simple as signing a statutory declaration in front of a magistrate /lawyer or filling out other paper work to get you through the process.
Aug 08, 2013 | pair motorcycle motorbike mirror for honda...
DR field and brush mower belt was off when delivered. I put the belt on and it came off again.
There is a bolt that can be tightened or loosened to tighten/loosen the blade belt. Look in the manual and/or call DR. Their customer service is excellent. I could explain it, but I'd have to write a small book. I promise you it's in the manual.
Aug 06, 2013 | DR Power Equipment Reconditioned 20HP...
Hpw to re wire a 50cc kids quad bike?
I would suggest you look at it as one circuit at a time. I don't know what is on the bike like for example, horn, tail light, head light, brake lights, you get the idea. the main thing to know is that the wire from the magnito is simply grounded to shut the engine down. So wire it that way, either with a key switch or push button, or toggle switch kill switch.
Jun 13, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
I just bought a white knuckle 300cc motor cycle.its been stood a year outside uncovered,the bike has no spark
IS THERE ANOTHER KILL SWITCH ON THE HANDLE BAR, CHECK THE WIRING TO THE COIL, START HERE
Jun 05, 2013 | Motorcycles
I recently purchased an older Kawasaki enduro, how do I find the year and model? The bike didn't come with a set of keys because the previous owner lost them over the years, do I have to replace the...
you can find manufacturing year on the chassis of bike and for your safety I suggest you to replace complete ignition switch, because you can not find the proper key if you find that is only adjustment which is not safe.
Sep 10, 2011 | kawasaki KX 250 Motorcycles
Pit SSR 110CC Pro Beginner  Bike Logo
549 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
