Question about Health & Beauty
We have a Sigma 8000 Infusion Pump that says "Fix 24" when we power it up. The error is due to someone not removing the clamp properly. I lost my instructions on how to reset the error
Manual pdf
http://www.meql.com/Manuals/Sigma-8000-8000-Plus-OPERATORS-MANUAL.pdf
call the company since they don't seperate the Fix# what each means...it's a generic answer
Posted on Feb 08, 2012
2 Suggested Answers
SOURCE: We have a Sigma 8000
Hey there!
According to the manual I have here in the lab, 'FIX 24' means that "User has improperly unloaded the set (lever has remained closed)".
Hope that helps!~
Posted on Apr 22, 2011
Sigma 17-50 2.8 EX HSM lens is stuck and won't zoom. It takes pictures Ok and sometimes it even focuses in automatic. I can also take pictures without zooming. Can someone help on how to fix.
Hi.
Probably the problem come from a loose screw inside zoom cylinder. Normally it happens due to constant use or vibration.
The GMR sensor is very sensitive to magnetized tools an needs an accurate position to function properly.
If you donĀ“t have experiencie with this electronic systems, it is better you to contact Sigma Service in Ronkonkoma, N.Y.
Oct 17, 2015 | Sigma Cameras
How to fix an error 99 on a Sigma 24-70 mm lens
The error 99 on your Canon is the last thing the camera can think of, if it really does not know what is wrong.
If you don't have the message when using a different lens, and the error keeps coming back with that lens, you are right it is in the lens. But again the camera can;t find out what.
The only thing you can do is make sure the contacts are clean and shiny and nothing os blocking free movement of all the parts on the lens. If you can't get it working correct, please contact a Certified Sigma service centre.
Apr 28, 2014 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
We have a Sigma 8000 infusion pump that keeps saying fix 4. We don't have an instruction manual so we are not sure what to do.
You directed this question at me even though I can claim no expertise in this area. FixYa tells me that by my posting this "solution" your question will be made available to other experts, one of whom hopefully will be able to answer your question.
Dec 20, 2011 | Office Equipment & Supplies
Sigma 8000 plus fix 24 error. I know what the error is for but how do you fix it?
Someone pulled out the tubing improperly. First check to see if all the tubing has been removed, and no little pieces have been left behind.
Step 1. Push Options. type code 89 then push enter.
Step 2. (on screen reads Set Bio Options) type code 430 then push enter.
Step 3. (on screen reads Password) type 9250 then push enter.
Step 4. (on screen reads Fix 00 then turns off).
Step 5. Turn on and check for any more errors.
Oct 08, 2011 | Cameras
What does the error message "out bin full" means
This error indicates that the sensor that detects when too much paper is stacked in the output bin to allow more paper to exit. This flag sometimes sticks and a quick check is to make sure that nothing has become jammed where the paper exits the printer. Most common cause is the flag getting jammed because someone has remove the paper the wrong way. I have never seen the actual sensor fail.
Jul 06, 2011 | HP LaserJet 8000n Printer
We have a Sigma 8000 infusion pump that keeps saying fix 24. We don't have an instruction manual so we are not sure what to do.
Hey there!
Hope that helps!~
Apr 16, 2011 | Health & Beauty
Kenmore dishwasher stock #16469 (Part #665.16469300) motor/pump made loud steady noise then stopped working. How do I remove motor/pump?
remove the D/W from power
remove the front bottom grille
reaching under the machine with a flashlight ;you will see a black rubber plug held on the pump bottom by a spring clamp remove the clamp with a spring clamp plier put your index finger in the pump and, carefully attempt to turn the pump impeller until it spins (the debris that was holding it will fall out
put everything back and, repower the machine
Aug 30, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Do you have the steps to replace the pump
Notes Power steering pump, replacing
Note: As the illustrations in this service information are used for different model years and/or models, some variation may occur. However, the essential information in the illustrations is always correct.
Preparation
Warning: Used fluid is considerably more dangerous than new fluid. Avoid skin contact with the oil.
Remove
  • the oil hose from the mounting on top of the power steering pump
  • the auxiliaries belt.
Note: If there is dirt in the fluid, drain the system and remove the hoses from the steering gear.
Removing the power steering pump/engine strut
Applies only to diesel cars:
Remove
113652509
  • the screw at the pump
  • the screw at the engine.
Leave the strut hanging in the delivery line.
Removing the feeder hose and delivery line
Install
113652510
  • the lock grip pliers on the feeder hose as close to the power steering pump as possible
  • the lock grip pliers on the return hose at the fluid reservoir.
Note: Place paper over the generator (GEN) as protection against oil.
Remove
  • the screw nipple. Remove the delivery line from the pump
  • the hose clamp. Remove the feeder hose from the power steering pump.
Warning: Avoid skin contact with the oil.
Remove
113652511
  • the 3 screws
  • the servo pump.
Installing the power steering pump
Install
  • the servo pump
  • the three screws. Tighten to 25 Nm .
Install
  • the feeder hose. Tighten the clamp
  • the delivery line. Do not tighten yet.
Installing the power steering pump/engine strut
Install
  • the strut
  • the screw at the engine. Tighten to 24 Nm
  • the screw at the pump. Tighten to 24 Nm .
Finishing
Tighten the delivery line. Tighten to 25 Nm .
Remove paper and lock grip pliers.
Install the auxiliaries belt.
113652512
Jun 06, 2009 | 2004 Volvo XC90
Broken garden hose adaptor
We have the same pump and problems. I have attempted a few fixes with PVC sealant and hose clamps to the current adaptor, however the adapter is still continuing to crack. The adapter is removable- carefully so as to not damage the small eyelet it attaches to, (or in our case, it came off on it's own) and can be replaced by any adapter that fits- they can be found all over at lowes or home depot. I am personally going to try using a broken hose and clamping it directly to the eyelet. This is not a good reason to buy a new pump- they fix too easy!
Mar 29, 2009 | Rule 1800 H53SP-24 Swimming Pool Cover...
Health & Beauty Logo
744 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
