Question about A4tech X-Slim KL7MU
On windows 7 X64 the volume buttons don't work.
I forgot my password and i dont know how to reset my toshiba satellite l25
Don't worry about it , I know the easy way to recover windows password, you can use the software called Smartkey Windows Password Recovery which is easy and effective to operate, and you can download and seethe using method from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
It can support Windows 8, 7,Windows XP, XP+SP2, XP+SP3, 2000, 2003, 2008, NT, Windows XP Professional x64Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems,Windows VISTA, Windows VISTA(64-bit).I hope it can work out for you.
May 09, 2012 | Toshiba Computers & Internet
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Jan 31, 2012 | Office Equipment & Supplies
I just installed windows 7 (x64) and now I can't use the volume, bluetooth or wireless LAN buttons that are above the keyboard.
check whether the drivers are installed?. they must not be there thats y the buttons are not working so try installing the drivers. u can get the drivers from acer official site. when u upgrade or install a new windows, it wont get all the drivers from the windows cd, and have to be installed from a cd or from online.
Sep 13, 2010 | Acer Aspire 5735 Notebook
I just bought ASUS K61IC-x3, where is preloaded windows 7 home premium x64. Also I have 2 recovery disks from ASUS - windows 7 x64 and windows 7 x32. If I want to set up windows 7 x32, do I need to buy...
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
Jul 29, 2010 | ASUS K61ICX3 Notebook
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Hello, i have Windows 7 X64, and I need the driver for the WUSB54 S V2.1
80% of the time, a vista x64 driver will work with windows 7 x64
Nov 04, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Driver for vista x64
Today I installed VueScan on my Win7 (7264) X64. After that the 1250 was still not recognized. Go to start and execute/run devmgmt.msc. You will get the hardware list with a yellow marker on your scanner driver. Double klick on that icon. Now you need to go to the second tab (driver program if I translate it) and second button (renew if I translate it) where you can install drivers for the device. Tell windows to search on your computer and point to the VueScan directory (directly on C: , not in programs). Now Windows 7 (7264) X64 will find the driver and your Epson 1250 is recognized. :-) Tested and working.
This same method worked for installing the AlexP drivers for my PS3 Eyetoy on windows 7 (7264). Tested and working also.
OoZic
May 08, 2009 | Epson Perfection 1250 Flatbed Scanner
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Apr 28, 2009 | Computers & Internet
PCI PARALLEL CARD WINDOWS VISTA X64
There are know compatibility and driver problems with Vista. Please visit the Microsoft update website for updates and driver issues.
Feb 20, 2008 | Televison & Video
A4tech X-Slim KL7MU Logo
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
