Question about LG 37LC2D Television
LG-37LC2D "SAME EXACT Problem"....BUT! Smelled
  • 34 Answers
SOURCE: LG plasma TV
I would suggest having the Y and Z Sustain boards replaced
Posted on May 22, 2008
  • 191 Answers
SOURCE: LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Posted on Oct 11, 2008
freetek
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
dave1645
  • 834 Answers
SOURCE: LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Posted on Nov 28, 2009
  • 2336 Answers
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Posted on Sep 24, 2010
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
"I have LG 37LC2D TV,when I turn the power on remote controlled or manually it immediately powers off. Is this an issue with the on/off switch inside the tv and how can remedy the problem?"
I have an LG as well.
My troublshooing says:
"Check the power control setting.The power supply may be interupted.
Check if the Auto sleep feature is actiated in the Time settings.
Refer to the " Sleep timer".
If there is no signal while the TV is on, the TV will turn off automatically after 15 miutes or so"
Feb 24, 2012 | LG 37LC2D Television
Hello, I just bought the lg 37lc2d off of craigslist and it has a password on it, how can I reset the password?
You can download the owner's manual for your TV here:
http://www.retrevo.com/support/LG-37LC2D-TVs-manual/id/371ci552/t/2/
Apr 23, 2011 | LG 37LC2D Television
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
Lg 37lc2d
Is it cracked? = needs new screen
If not, you could get luck reseating the cables internally (unplug and replug).. some are fragile but sometimes reseating cables will fix these issues..
Nov 28, 2008 | LG 37LC2D Television
Televison & Video Logo
