Question about Cycling
Falcon MLG-26i dyna grip stiff gear change especially around postions 1 and 2, how can I loosen so an 11yo can cope?
4 Suggested Answers
SOURCE: i need a grip shifter
You can purchase a new 6 speed SRAM grif shifter for about $9.00 on Cambria Bikes.com They even come with derailleur cables installed!
I purchased a few 6 and 7 speed versions for my bikes, and they work fine.
Posted on Oct 10, 2009
  • 5 Answers
SOURCE: why cant I change gears on my bike?
Have you tried the use WD40 or GT85 Lubes on the seized parts? This is usually enough to free this sort of problem.
Posted on Mar 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: Where do I buy a
Google.
For example:
http://www.bikepartsusa.com/bikeparts/item/01-129762/shifter/Pyramid--Shifter-56-Speed-Falcon-Right-Only&category=shifter
Posted on May 01, 2011
How do I change the throttle cable 2002 dyna super glide
You have to loosen the cables from the grip then open the switch cover there you are at the cables knobs , take the one you want to change off it's retaining hole , it should be eazy since no more tension on it , then go to the carb , take that cable off it's brace and do the same as with the grip . For putting the new cable on just do the reverse steps . Make sure when you adjust the cables back they're not too tight or the throtle won't respond good .
Now have a nice ride
Oct 02, 2014 | 2004 Harley Davidson FXD - FXDI Dyna Super...
How do i talk off my old grips?
Right grip will come off when brake perch and switch housing comes off. Left grip is usually glued on and when clutch perch and switch housing is removed it is usually cut off but if a screw driver is worked down inside of the rubber grip and some brake kleen sprayed in between the screwdriver and the grip and the screwdriver is wiggled and worked around the rubber grip will usually come off undamaged.
May 19, 2014 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
Falcon mlg 26i
Car and truck gearboxes don't have Derailleurs They have forks, layshafts and torque convertors.
May 02, 2013 | Cars & Trucks
I need to replace the shift cable on a falcon mlg-26i. How is this done? Thank you,
You web search "replace bicycle shifter cable" for all kinds of video help and use something like this as a reference for almost anything, plus the right tools...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Sep 22, 2011 | Falcon Basic Essentials of Bike Touring
Why cant I change gears on my bike?
Mar 06, 2010 | Falcon Cycling
1996 dyna convertible clutch adjustment procedure
i have a 2001 softail and when you first crank it up it wants to grind when putting in gear. after it warms up its better, but it is still stiff to change gears. there is no slack in the lever handle, but when it cold and you put it in gear it seems like the clutch is draging a little. any suggestions???
Aug 29, 2009 | Harley Davidson FXDL Dyna Low Rider...
Cannot figure out how cable threads through
This video may help
http://bicycletutor.com/grip-shift-cable/
May 23, 2009 | Cycling
Gear shift adjustment with boots on, trouble shifting gears
The dealership should be able to help you there. Often the shift pedal from an earlier model will work well. The factory changes things in a effort to improve the product but some changes are not as good as intended.
Mar 11, 2009 | 2008 Husqvarna WR 250
I need a grip shifter falcon MLG-26i dyna grip 6 speed where can i locate one thanks
Jan 03, 2009 | Cycling
Cycling Logo
112 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
