Question about Gigabyte GA-6VTXD Motherboard
Asus P4PE (6 PCI, 1 AGP, 3 DIMM)
I have this motherboard on my PC, my son did something wrong, maybe deleted installation drivers and now it doesn't work anymore. I need that drivers again because I don't have it. Please, help!!!
Thank you, Stefano
  • 2,794 Answers
Try this link on Asus to get the drivers you need
Asus sorts motherboards by socket type on the motherboard. You will need that information to get the driver screen for your motherboard to appear.
Posted on Aug 04, 2008
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Helo mr
Hello you mainboard support Memory configuration:
Dual-channel memory architecture
4 x 184-pin DIMM sockets support up to 4GB of unbufferred non-ECC 400/333/266 MHz DDR DIMMs
so it wont support DDR2
and for the VGA
it is
1 x AGP 8X
so you can put only up to vga card to 8x and no pci express or something like that WILL NOT BE COMPATIBLE TO YOU BOARD
Jan 22, 2010 | ASUS P5P800-VM Motherboard
Where to get pci driver
should be on your install disk that you got with your board
Dec 10, 2009 | ASUS P4PE/L (ASU49J) Motherboard
Perdi el disco de drivers de la tarjeta Abit SG-72
Bajalos del website de ellos, problema resuelto.
Apr 18, 2009 | Abit SG-72 Motherboard
Installing extra memory causes freezing + closing down of pc
Check these specs for your will support 2gb but only if its pc2700.anything greater will not boot or become unstable are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
Max. video card or controler
Get the AGP card with the most memory you can get.AGP is a pretty old architecture. You may need to hunt one up on ebay. Might try
Nov 21, 2008 | ASUS P4B533 Motherboard
Audio Device intagrated in Asus Mother Board
Try downloading Microsoft UAA drivers and install first
Uninstall your sound driver install UAA drivers then install sound drivers
Oct 13, 2008 | ASUS K8V-MX Motherboard
Gigabyte GA-6VTXD Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
