Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer just stoped working.
My dryer is 2 years old and it just stopped working. It does nothing as if there is no power being supplied. It was working, but it did smell like some wires might have burned. Is it worth fixing?
  • Anonymous Aug 12, 2008
    i have the same problem, but smelled no burning wires. I dried 2 loads of laundry, went to start another, and nothing, checked all fuses, checked power supply in wall for dryer.Help..........
    Problem Solver:
  • 18 Answers
Chances are it may just need a new connector in the back where the power cord connects. Check it and see if you can tell where any wires have been damaged. This is usually very easy to do with little or no disassembly.
Posted on Aug 04, 2008
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
Dec 23, 2017 | Maxtor Computers & Internet
I have a 22" flat
Power supply board it have dead components parts could be anythings on the board.Tv is under a year.Tv still under warrenty call Philips and take ur warrenty repair.
Aug 08, 2011 | Philips 22PFL3505DF7 22 in LCD TV
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
Stoped working
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 30, 2009 | Miele Dryers
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
2 year old E machine
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Jul 29, 2008 | E-Machines eMachines Desktop PC
Frigidaire GLEQ2152ES Electric Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
