HOW TO REPLACE BULB ON DIMPLEX CLUB STOVE HEATER
    Brigadier General:
  • 4,736 Answers
On the back of the stove, you will see a rectangular access panel near the bottom of the stove. If you remove that, you will have access to the bulbs. They are 60 watt, small base chandelier bulbs.
Hope this helps you change the bulbs.
Posted on Mar 28, 2011
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
Dimplex club heater flicks on/off either on manual or using remote
It sounds like a dodgy thermostat or thermistor to me. When a thermistor goes wrong it can cause what is known as rapid-cycling in a heater, where the unit will keep switching on and off, on and off repeatedly.
May 28, 2014 | Dimplex Compact Electric Flame Stove...
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
How do I replace the light bulb in a Dimplex Springborne electric stove?
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
Have a melted plug on my heating stove . what causes that and what can I do
Be glad you caught that in time. The overheat or overload sensor for your electric stove-heater has failed and needs to be replaced. If it is still under warranty, Dimplex will repair or replace it at no cost. Even if it's not still under warranty, Dimplex Technical Service wants to know about this. If you live in the USA or Canada, you may call them at 888-346-7539. If you live in the UK call 0845 600 5111 and ask for Technical Service. Either Dimplex USA or Dimplex UK, can provide the part if necessary.
Do Not use your stove-heater until this is repaired.
Hope this helped you. Please let me know.
May 25, 2011 | Dimplex Compact Electric Flame Stove...
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
464 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
