Our lanier lp226cn printer has a service call error of SC542. What does this mean and how can I override it?
2 Suggested Answers
Ranglo
  • 1194 Answers
SOURCE: I have a Lanier LP226cn
Thanks for using Fixya.
SC545 is a fuser warm up error.
Try resetting the error by holding the up and down arrows together for 10 seconds, and then press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on.
If the error is still there then you will have to take your device for repair.
Good luck and have a nice day.
Posted on Nov 10, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
How do I reset a Lanier 226CN Printer with an error code: SC542
In order to clear error SC542, you can perform the following:
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arrow to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
Please let us know if this works for you.
Also, check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made. read this TSB on updating the thermistors: TSB_106 SC555_SC545_SC542 Occurs.pdf (need to register to views).
Hope helps.
Apr 04, 2011 | Lanier LP231CN Laser Printer
I have a Lanier LP226cn printer. Under the alert status it is telling me to ''Prepare a New PCU'' and ''Replace CPU Black Soon'' I understand it means to replace my Black Toner soon as someone mentioned...
Sorry, You do not need Black toner, you need a Black PCU (Photo Conductor Unit).
I have this same printer with the same warning.
Unfortunately, This unit seems to be rather expensive.
Good Luck
Mar 01, 2010 | Lanier Office Equipment & Supplies
Lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
Sep 14, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Lanier lp226cn error code sc545 printer won't work, maybe a fuser error? new and has not been used enough for this to happen!!! Can I re-set this?
Hold the up and down arrows together for 10 seconds, and press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on. Try it. It is a fuser code, and it just might be dirty where the sensor touches.
Jun 03, 2008 | Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
186 people viewed this question
k24674
jasbo
jasbo
