Question about LG WM2233H Front Load Stacked Washer / Dryer
My washer stopped working in the middle of a load. House circuit was tripped, I reset the circuit still no response to the washer no light no power, there is power coming from outlet. Is there a internal reset button? or something simple to look for or should i just call a pro?
    Brigadier General:
  • 6,277 Answers
Sorry, no internal reset button- call a pro ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 28, 2011
LG WM3455H won't turn on.
Unplugging to reset only works when the washer has power and on stand by. Start by checking the fuse on the noise filter, that is were the power cord connects to. If good than your main board is bad.
Apr 06, 2014 | LG Front Load Washer / Dryer Combo...
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
The washer shuts down in mid cycle
Hello. LG washing machines come in a widevariety of models, each with unique features, functions and design. Many of thebasic functions of each model are universal when it comes to running the washcycle. If the washing machine stops in the middle of a wash cycle, the firststep that should be taken is to perform troubleshooting steps to determine thecause of the problem. After the source of the trouble has been established, itcan be resolved in most cases by continuing the troubleshooting process. 1 Make sure the lid is completely closed. Certain partsof a wash cycle will not start if the lid is not closed.
2 Check the load to see whether it isunbalanced. If the washer gets off balance, it may stop in the middle of acycle. Redistribute the clothing so that it is evenly balanced around the drum.
3 Make sure the hot and cold water faucetsconnected to the washing machine are turned on fully. If the washing machine isnot getting enough water, it will not be able to complete the cycle.
4 Inspect the drain hose for clogs orobstructions. The washing machine may stop if it is unable to drain waterproperly. Check the drain pipe that the hose feeds into for clogs or debris.
5 Check the house's circuit breaker panel orfuse box. The circuit may have been tripped or a fuse may be blown. Replace anyblown fuses and reset any tripped circuits.
Thanks for visiting
Sep 07, 2011 | LG WM-2277HW Front Load Washer
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    My matag atlantis just stopped working. It will
    no reset, check the receptical you could have tripped you house circuit or fuse
    Feb 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
    No electricity in all bathroom outlets
    you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
    Mar 09, 2009 | Siemens Electrical Supplies
    Machine fuses house RCD if a drying cycle is selected
    Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
    May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
    LG WM2233H Front Load Stacked Washer / Dryer Logo
    292 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
