Question about Minolta Office Equipment & Supplies
Error Code C1334 on Minolta DI450 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,850 Answers
Something wrong with duplexer that would be draw #2 or #3 the one no paper goes in check for paper in the back or there is fault with that part of the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 28, 2014
2 Suggested Answers
SOURCE:
leroyal
  • 2120 Answers
SOURCE: We have a dark line
Lift up the keypad / document feeder section of the fax machine and look for wite-out on the small glass strip.
Posted on Sep 25, 2008
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
How to reset to factory default
Sir, reset what part like access code etc. Di450 series great machines rugged. Service mode Memory Clear?
Dec 19, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
short of the number of sheets of paper to be taken
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
Minolta di450 code: c1080 & c1082
di450 error code 1082 give me a solution
Dec 14, 2012 | Office Equipment & Supplies
Minolta Di450 service code reset service code C1326
di450 . what is the solution of this code 1326?
Jun 09, 2011 | Minolta DI-2010F Copier
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di450 Error C1326
how to remove di 470 minolta error c1029
Dec 17, 2007 | Minolta DI-2010F Copier
110 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
