Question about Ricoh Aficio SP C811DN-DL Printer
Error message Hi, Our colour Ricoh C811DN printer displays the following error message: Service Call SC548 Please Call Service Should I arrange for a tech to come and resolve the error or can you tell me what to do? I'm thinking that it may be a fuser issue? Can you advise, please? Thanks much. Rose rganpat@atlanticlng.com
  • pennpp1 Nov 18, 2008
    I have the same error code sc548. I get a new fuser kit installed but still having the same error sc548.
    HELP!
  • Ricoh Master
  • 2,794 Answers
It's the fuser. You can try turning it off, wait 30 seconds, and turn it back on again.
If the problem continues, call a technician in to get the thermistor replaced.
It's a common error.
Posted on Aug 04, 2008
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
We have an SC548 code on our Ricoh3500
"Fuser not installed error code". Did you have a paper jam in the machine? If so open the right door and make sure that the fuser unit is correctly set. You have two tabs on the end next to them are levers lift them, then pull on the tabs "C1" fuser unit(unit that gets hot) pull on them then the unit will come away from the machine slide it back into the machine making sure not to slam it. Close the machine.
To reset the error code go into service mode "clear 107 stop hold the stop down for 5 seconds" select copy SP then 5810# execute then restart machine. Hope this helps.
Nov 10, 2013 | Ricoh Aficio SP C811DN-DL Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Servicecall
on the copier:
press clearmode then 107 then hold clear/stop until a new screen comes up. then press Copy Sp, then type in 5810, then hit execute, then exit out of everything and turn it off for 30 seconds. If the error comes back up place a service call for the fuser.
Jan 17, 2008 | Ricoh Aficio SP C811DN-DL Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN-DL Printer Logo
731 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
