Question about Garden
Im trying to put a gas tank back on a 5 horsepower briggs and straton motor, i forget where the wires hook up and the smmal spring and the linkage rods. is there a picture or something that can show me this thank you
    Novelist:
  • 111 Answers
If you have the Model, Type and Code off of the engine flywheel housing you can go to www.partstree.com and put it in on the Briggs and Stratton Engine Brand.   You have to scroll down to the lower part of the page. This should direct you to the correct engine and from there you can select what part of the engine you are needing help with. It will show you a diagram of how the parts go back together.
Posted on Mar 30, 2011
I took off gas tank on my Briggs tiller to clean it out. cant get the wire linkage on
take the tank off again, fit the linkage by turning the tank , then refit the tank.
May 03, 2017 | Briggs Garden
How to put spring back on carburetor on murray 5 hp push mower?
Hard say exactly without model of engine, but on most small briggs engines is as follows. One end of the spring will hook into the loop of the linkage wire that connects the governor to the carburetor butterfly and the other end will hook into to O of the throttle plate. Thus as you move your throttle plate to increase your engine rpm it applies more tension on the spring opening the governors up and vise versa when moved to lower your rpm's. Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Aug 27, 2014 | Garden
Fix leaky plastic gas tanks
this is a warranty repair by brigg and straton done at any lawn mower shop
Sep 13, 2012 | Briggs & Stratton Garden
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
We have a 6.25 /Briggs & Straton we have cleaned
You should have two fuel lines going from the carb to the tank, one has a filter,
make sure both lines are good without any breaks or cracks. if the filter is dirty
you may need to replace it. you can fish it out of the gas tank by making a hook
on a wired coat hanger, try to remove the filter and put the line back in the tank
make sure they are both submerged, if it runs just replace the filter, good luck!
Jun 26, 2011 | Briggs and Stratton 020275 Elite Series...
The engine starts ok but it keeps revving up and down, as though its about to conk out, although, so far, it hasn't. It has also started to blow out some white smoke? I have changed the spark plug - but...
Your Briggs & Stratton has a Sprint or Classic motor on it. Every few years, the diaphragm in the carburetor must be replaced.
Briggs part #495770
1. Remove the air filter assembly. This is a good time to clean and re-oil the filter.
2. Remove the 3/8" head bolt from the front of the fuel tank.
3. Remove the 1/2" head bolt from the side of the fuel tank.
4. Gently pull the fuel tank assembly toward you and tilt it away from you. While doing this, you will need to unhook the governor wire from the throttle plate.
5. Drain the gasoline (you can use it again later)
6. Remove the 5 screws that hold the carburetor on top of the fuel tank.
7. Pull the carb straight up. Be careful not to lose the spring or strainer on the bottom of the carb.
8. Remove the diaphragm.
9. Clean the carb and tank surfaces with carb cleaner spray.
10. Open the package with the new diaphragm in it. You will find 2 pieces. One is rubber, the other is paper.
11. Place the rubber diaphragm onto the fuel tank, then the paper one. Gently reinstall the carb onto the tank.
12. Push the 5 screws back into the carb. Before you tighten any of the screws, have all 5 pushed through and wiggle the carb a little, this will allow the diaphragm to align properly. Tighten the screws.
13. Reinstall the tank/carb assembly. Make sure you hook up the governor linkage.
14. Inspect the governor spring(s). They should be connected on both ends. You should not disconnect them for this repair.
15. Reinstall the air filter, gas, prime, and GO!
Good Luck!
Oct 25, 2010 | Briggs & Stratton Garden
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
