Question about Ashdown Klystron 500w Bass Amp Head
Hi ther the fuse has blown on the speaker out circet on my new amp any ideas why this would happen?
  • Ashdown Master
  • 5,603 Answers
The fuse blew because of excess current. The cause of the excess current is either excess volume, a short in the speaker, OR the amp has failed and is shorted to one of the power rails internally and is driving DC current out.
Replace the fuse and use a meter to check the output voltage with NO speaker connected. It should be under 1/2 volt period. If it is, then check the resistance of the speaker. The DC resistance should be a little less than the rated impedance. Otherwise if the amp is kicking out a higher voltage or blows the fuse again, have the amp repaired.
Posted on Mar 28, 2011
B115D
Hi, your amp has a short if the fuse is blown - it needs to be repaired - we can fix it - look on ebay. Thanks.
Mar 12, 2014 | Behringer Eurolive B115D Powered PA...
I have a marshall jcm 900 slx 100 watt head and 1960a cab, when i went to use my amp i got no signal from my guitar. none of the fuses had blown and there was still a hum coming through the speakers. I...
It sounds like you have a dead guitar cable or the preamp section of the amp is blown. It needs to go to the shop. It's way cheaper in the long run to just take an amp in. If you try poking around without knowing what you're doing you can fry something more expensive or worse yet yourself! There are leathal voltages in a guitar amp!
Aug 17, 2017 | Music
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Hi I ve had the cd10 for a year and it's been used twice . The problem is the amp powers on with out the popping speaker sound the led is showing red which is the powers on but get no sound what so...
Hi there.You may have a blown fuse.Unplug the amp then undo the screws that hold it all together.Remove the wires off the speaker and put an AA battery across the speaker connections(of the speaker).You will hear a clicking sound if the speaker is ok.If not then the speaker is blown.This could also damage the circuitry.Check the fuse(s) and replace with exactly the same rating.Assemble and test if still no go then the circuitry is faulty.You could then take it to a repair shop and ask for a quote to repair it.
It might be cheaper to buy a new unit.
Jul 16, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Is there a fuse in this amp? is it replaceable without soldering?
Hi, blowing a fuse in an amplifier is a problem that most guitarists face at one time or another. If an amp won't turn on, or it turns on for a second, then makes a popping sound and turns off, the problem is usually a blown fuse. Though a blown fuse can be a hassle, especially during a performance, it does not have to put a stop to your musical enjoyment. With a spare fuse you can be back jamming to your favorite tunes in no time flat.
Things You'll Need
Fuse.
Instructions
Turn off the amplifier and unplug it from the wall.
Locate the fuse, which is usually found at the back of the amp. The fuse will look like a small black wheel sticking out of the amp with a number and the letter V next to it. For example, 9V.
Gently turn the fuse counter-clockwise to remove it from the amp.
Discard the old fuse.
Insert the new fuse into the empty fuse slot and turn it clockwise until it is firmly in place.
Plug in the amplifier; make sure the power switch is in the off position.
Turn the amplifier on to make sure the new fuse is working properly.
Hope it helped..
Jun 14, 2011 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Brand New Ampeg Ba 600 210. Only Used durin 2 shows. Sound is awesome. Go to use it this weekend and absolutely no sound at all coming through the speakers. Compression, eq and Everything else working when...
Another person posting on here I suggested opening his unit and he had blown speakers. I think these that are DOA after previous use may be blown during the previous shutdown of the amp driving them and those with built in amps are blown when mixer is powered down putting out a large pulse. Hopefull the amp is blown rather than the speakers... cheaper to repair. Open and check for a fuse, but dont' replace it until you find out the cause of it blowing as additional damage can occur.
May 15, 2011 | Ampeg BA600-210 Bass Combo (with )
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
No matter what i do, my speakers sound very basey, ther is no mid or treble and tried everything 2 correct it through my mixer 2 no avail, is ther sum setting that is needed 2 correct this problem
This is not likely to be an amp problem unless there is a built-in crossover. I don't recall if the 26oo has that option. Check for that first. Other than that, you probably have blown tweeters in the speakers. Check the speakers and update this with your findings.
Dan
Nov 25, 2010 | Peavey Pv 2600 Power Amplifier
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Ashdown Klystron 500w Bass Amp Head Logo
181 people viewed this question
Top Ashdown Music Experts
Michial Gueffroy
Are you an Ashdown Music Expert? Answer questions, earn points and help others
