Question about Canon Cameras
When I turn on my power shot sd 110 the monitor is dark and has red lines running through it. the menu displays when I hit that button.
  • 684 Answers
Pls try to change the memory card it will work fine
Posted on Aug 04, 2008
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
When i turn on my LG 32lg30 on, the power indicator light flashes red 4-5 times, then the monitor turns on to a steady dark blue color. I tried to press buttons on the remote but there is no display.
Now there is a challange.
My LG has not shown this behaviour yet. Do you still have the DVD disk that came with the TV.
If you do you will get your answer there I presume.
Make sure that you are using the correct input.
Feb 21, 2012 | LG 32LG30 32 in. LCD HDTV
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
Hi how do i formatt my camera card
From page 63 in the manual.
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
Link to manual:
Jul 05, 2011 | Samsung Digimax 201 Digital Camera
Monitor problem
If you restart your computer and either go to the Bios setup menu (usually by pressing DEL or some other noted key, in the first few seconds of power up) does the same "contrast" menu still appear?
If so, then it must be your monitor (likely Monitor, not computer)
Your monitor is mad at you and it is displaying a Warning Message that is part of its OSD (On Screen Display). Some monitors are more sensitive then others so it takes very little to get this type of message. To get rid of it you will need to use the buttons on the monitor to get into the OSD menus. You need to look for something like "OSD Settings" or "Warning Message Settings" which may be found under "Setup Menu" or "Options Menu". This all depends on the make and model of the monitor as they are all slightly different.
Once you find this area you will need to turn off a setting that will be called "Warning Messages" or "Display Notifications", again the wording may be different but the idea is the same. Once you find the setting you should have the choice to set it to "ON", "OFF" or to an amount of time it will display (5 seconds, 15 seconds etc...).
On my Viewsonic the setting is found under "Setup Menu", and then I turn off "Warning Notification".
ps. If the display looks OK then there is most likely nothing wrong. The message appears because the monitor detects a setting that may be in error. If the message goes away after a bit and doesn't bother you, you may choose to ignore it.
May 24, 2010 | AOpen A75PF Monitor
I have a dell Dimension 2300 and the images are very dark. I don't think it is from the monitor.
Try these steps: 1. Check the monitor settings. Access the On Screen Display (OSD) Menu System. Adjust the contrast and brightness using the control buttons in the monitor.
2. Run the monitor self test. Unplug the video cable from the computer (cable from monitor to the back of the computer). Usually it has a blue or white connector. Turn on the monitor alone. It should display the self test pattern (white, red, green & blue). If the images are dark in the self test, it is a problem with the monitor.
2. Rotate the monitor to face a different direction. This will help in eliminating sunlight glare which can cause poor picture quality.
3. Test your computer using another working monitor. If the problem occurs in a known good monitor, then it is a video card or motherboard (if your video card is integrated) problem.
I hope these options help.
Jan 19, 2010 | Dell Dimension 2300 PC Desktop
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Monitor stops showing desktop
probably needs new voltage regulator for backlight. it would probably be cheaper to just buy a new monitor
Aug 14, 2009 | Acer 22" X223w LCD Monitor
Dell display is dark
Leave the monitor hooked up to the computer with you booted up into windows.Go into the menu on the monitor itself. There should be a button on the monitor itself that will allow you to go into its own menu. From there try to find the brightness and contrast controls and turn them up. If after you turn them up the display stays dark then your monitor is bad and it will need to be replaced.
Dec 30, 2008 | Dell E153FP 15" LCD Monitor
Cameras Logo
29 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
