Question about HTC Desire Cell Phone
My HTC Desire turns off and on by itself...No water damage. Tried the paper over the battery and taping in the SD card....Any thoughts?? I've had it for about 6 weeks...
Im not sure if this is the same problem but my husband has an htc evo and we found that it was just sleeping. he has a button that just wakes it up. unless it restarts everytime then im noy sure. sorry if i couldnt help
Posted on Mar 28, 2011
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Was having problems with mini SD card in my HTC Desire S as it kept unmounting. Following advice from work colleagues and forums, I transferred all my stored memory from the mini SD card to my laptop
I don't think you lost your pictures. Same thing happened to my phone. I brought it to the HTC Service Center and they upgraded the software. I suggest you take it to the nearest HTC Service Center so the problem can be resolved.
Jul 13, 2012 | HTC Desire S Cell Phone
Why does my HTC desire s keep turning itself off?
Sounds daft but I'd put a piece of folded paper on top or bottom of the battery to ensure it has perfect contact and isn't able to move at all. I have heard of others who have experienced this issue.
If problem still there then change your battery. This is not a software issue so Don't factory reset.
May 14, 2012 | HTC Cell Phones
My htc hd desire keeps switching itself off unless connected to the charger
This problem used to happen all the time with my last phone. After looking at the battery, I realized it was a little loose. Honestly, I just ripped off a small piece of paper and folded it a few times and stuck it in to make the connection tighter. Easiest way I ever fixed something, worked perfectly. Hope this helps.
Jan 26, 2012 | HTC Desire HD Cell Phone
HTC Desire S Unlock codes needed for o2 SIM on ORANGE phone
you can Unlock your HTC Desire S with imei unlock code. it is very simple and eaisiat way to unlock your HTC Desire S. get your HTC Desire S Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Dec 29, 2011 | HTC Desire S Cell Phone
Can i use a Micro sd hc memory card in an HTC desire?
Yes! an HTC Desire is compatible with microSD™ memory card (SD 2.0 compatible)
Jul 21, 2010 | HTC Desire Cell Phone
Keeps saying sd card removed when its clearly in!!
i recently bought a used g1 from a friend and tried to insert an sd card but it said the same thing sd card removed the card is fine then i did some researching and found out that the q1 has a sensor in the sd card cover which if it is opened it will say that message now my problem is that the cover is broken so i am currently working on a solution to that but if it is not broken then just try taking the sd card out turn off the phone and insert the sd card and properly close the cover make sure it is not opened even the slightest then turn your phone bak on and it should work unless the actual sd card reader is damaged or the sd card itself. hope this information was helpfull
Feb 28, 2010 | HTC G1 Smartphone
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
HTC Desire Cell Phone Logo
222 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
