Question about Nintendo Super NES Console
What if the sky was the colour pink then? - Nintendo Super NES Console
    President:
  • 894 Answers
Well that would be nice then.
Posted on Jun 20, 2011
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Mar 13, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Vertical colored lines
Hi.If you have a Nvidia Graficcard, it could be it.overheating problem at the motherboard.you need 2 replace motherboard, or reflow, reball graficchip.it's a common problem at Nvidia 6XXX, 7XXX, 8XXX model grafics..
Dec 29, 2013 | Sony VAIO Computers & Internet
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
What would happenand what if the sky was the color pink then?
I ahve no clue it would be pink instead of the colour blue then.
Apr 25, 2011 | Nintendo NES Console
Background telly noise
This is a very common problem caused by poor design of the SCART system which allows cross-channel feedback.
At the TV rental company I worked for we cured it by supplying "cut" SCART leads; usually these leads are completely reversible, but on a cut lead one end is designated only for the TV.
They are commercially available and easily identifiable as one plug will be labelled "TV" and the other as "video" or you can make your own using one of the generic cheap SCART leads which allow you to open the SCART plugs to access the wires:-
Open the plug and identify pin 20. They will have moulded numbers, but pin 20 is the one which is in the angled corner of the plug. The wire should usually be pink, if it is green then check pin 19 which is directly above pin 20. If this wire is pink then cut it. If the pink wire was on 20 then label the plug as being for video/Sky, and if it was on 19 then it's must be labelled for TV. Now do the other plug, whatever the order of the pink and green wires on pins 19 and 20 was on the first plug will be reversed. Cut the pink wire again. If the colours don't match then just cut the wire from pin 20 (video/Sky) at one end and from pin 19 (TV) at the other end.
Reassemble everything and plug it all in correctly and your problem should be fixed.
On a slightly different matter, never waste money on over-expensive "upgraded" SCART leads. They may look good but you're just flushing money down the toilet.
I hope that this has solved your problem, all that I ask in return is for you to take a moment to rate my answer.
Feb 14, 2010 | LG 42LC2D 42 in. LCD HDTV
Got a new dvd recorder but the a v cords are black and red where does the black one go? also have sky running through t v do I have to run sky through the dvd player too
the colours are just for convenience; it doesn't matter which colour goes where as long as the port colours are the same at each end. i.e a black cable can be used for red ports.
Yes you will need to run sky cable to recorder then to TV if you want to be able to record SKY. This also means that you will have to have your recorder on even when only using SKY
Sep 21, 2009 | Televison & Video
Toshiba TV colours wrong pink sky, blue clouds and green people??
Inside your TV there is like a loop of insulated wirings the loop around the screen. This is to demagnetized the tube. There is a varistor which looks like a thick coin with two leads on it, or sometimes it looks like a flat ceramic capacitor that control this loop of wire. When you first turn on your TV current goes through the loop of wires to demagnetize the TV then the varistor shuts off. Sometimes this varistor fails, causing smeard colors. You can also demagnetize the screen without opening the TV. Using a hand held demagnetizer. It can be purchased at some electronic parts store.
Jun 28, 2009 | Televison & Video
Colour balance for majority of photo is good but sky or white goes to pink. Colour balance is obviously not the problem. Help?
How about White Balance? Taking a photo outdoors, for example, white your WB is set on "Fluorescent Light" will turn your images bluish. To set WB, see the owners manual.
Jun 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Distortion on people faces
What does a dvd look like played on it? If it's the same then there is something wrong with the TV. If a dvd looks good - no color problem - then it's the sat box that needs replaced.
Mar 25, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Nintendo Super NES Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
