Question about ASUS M2N68AM Plus Motherboard
I turned off the pc 3 days ago thru windows XP normal shut down. Now I can not turn it on, I hit the power button but nothing at all.
    Genius:
  • 1,400 Answers
Hello
First verify the electrical outlet is working by plugging a lamp or something else in.If your using a power strip be sure the little fuse has not popped out or take the power strip out of the line.
Next verify the power cord for the pc is getting power through it,using a vollt meter plug in the line and measure voltage at other end.
last,move rocker switch on the back top of pc to 120 volt position.If none of the above work you will need to open up the case a see if any thing became loose or disconnected.Possible your on off switch is bad on the pc.
Posted on Mar 28, 2011
  • 1 more comment
  • imjarhed Mar 28, 2011
    I have done all the above, thank you. Was thinking power button also but have no idea what to do with that. Appreciate the quick response.
  • mpcheesman1
    mpcheesman1 Mar 28, 2011
    usually you can check the wires are connected for the button.Also if you are good with electric you can jump the button out and see if it starts.Im not sure you can get just a button,you may need to get a new case.Check out www.newegg.com
  • mpcheesman1
    mpcheesman1 Mar 29, 2011
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
Why doesn't my laptop start?.
remove the battery for about a 5 minute then insert it again, then press the on button
Jun 03, 2014 | Computers & Internet
Hi, we have an Inspiron and it has been working perfectly normally and now we have turned it on and the screen says Windows Error Recovery - I try both options - Launch Startup Repair (recommended) AND...
Please try the steps mentioned below and i am very sure that this will make you happy...
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Good Luck!!!
Jan 16, 2011 | Dell Computers & Internet
TURNS ON , GOES TO START NORMAL OR SAFE MODE, GOES THRU THE WINDOWS XP SCREEN AND THEN GOES BLANK
Follow the steps below,
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode".
Step 6: If you able to login then try accessing System Restore.
Step 7: Click on Start and then click on All Programs.
Step 8: Choose Accessories and then System Tools and System Restore.
Step 9: Run the wizard by choosing "Restore My computer to an Earlier stage"
Step 10: Choose a date displayed in Bold in the calender.
Step 11: Your computer would reboot and wait until the restoration completes.
Hope this helps.
Dec 27, 2010 | Acer Aspire One PC Notebook
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
At about 3:00 am on thursdays, Windows XP closes and C drive shuts down. It is not a re-boot because the motherboard power stays on. When I turn the computer off and turn it back on (the 1st time)it...
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
Mar 12, 2009 | Gateway GT5056 PC Desktop
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
ASUS M2N68AM Plus Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
