Does my hard drive plug into the blue or white ide plug
    Champion:
  • 232 Answers
THE PLUGS ON THE CPU BOARD ARE CONFIGURED TO ACCEPT ONLY CERTAIN PLUG CONFIGURATION EXAIMNE THE IDE PLUG AND THE SLOT AND SEE HOW MUCH OF A MATCH THEY ARE. ITS REALLY NOT A MATTER OF COLOR BUT PIN CONFIGURATION.
Posted on Aug 04, 2008
SOURCE:
Replace hard drive
The eMachine T3995 hard drive was originally an IDE 250GB drive. These drives are obsolete and hard to find.
I suggest using the following Generic IDE to SATA device on Amazon for about 7 dollars and then replacing the IDE drive with the SATA drive of your choice such as the 320GB Western Digital Blue listed on Amazon at about 25 dollars. Both IDE and SATA drives mount the same way.
Feb 08, 2013 | eMachines T3995 Power Supply Part Number...
Unpluged small ribbon cable from mother board installing hard drive need to know where it plugs in
If it's an IDE cable it goes into the IDE 0 or IDE 1 on the motherboard.
It's your primary drive so it should go into the lowest number.
If it's an sata drive the and it's your primary drive it goes into the lowest numbered sata port on the motherboard.
May 24, 2012 | HP Computers & Internet
Should the sata cable be hooked up to the cd drive or the hard drive and where can i find pictures of where the inside cables should be attached to
One end of the Sata Cable is to be attached to the CD/DVD (Optical Drive) or Hard Disk, whereas the other end is to be attached to the motherboard. The Sata connections on the motherboard are located near the CMOS/RTC Battery as indicated below: - (Blue, White, Yellow and Black, at right-hand top corner)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | HP Pavilion a1540n PC Desktop
What is the slave patern for 500 gig hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 10, 2010 | Western Digital WD Scorpio Blue WD5000BEVT...
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I wish to change my hard drive from ide to sata
SATA plugs are eith red or black. Usually grouped in four. They are plastic about 3/4 inch long and a 1/4 inch wide. I looked up your motherboard and the SATA connectors are actually blue. Located to the right of the green connectors.
Feb 25, 2010 | Foxconn Computers & Internet
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
Dell gx280 hard drive and dvd drive
You can buy adapters for this very thing. Less than 20 bucks at most computer stores. I looked on newegg and they were 11.99.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822998001
Nov 30, 2008 | Dell (2336V) Motherboard
Sony Pcv-w 600G hard drive replacement.
Replacing a hard drive is very simple. A hard drive will have two connectors a one for power(small plug usually white with 4 holes ), and an IDE cable that looks like a ribbon. You just have to remove the cables from the old hard drive and plug them into the new one.
An IDE cable looks like this(clcik here)
You see the four holes next to the IDE cable? Thats where the power connector is plugged in. Let me know if you need anything else.
Sai.
Aug 07, 2008 | Sony VAIO PCV-V200G PC Desktop
Wd300ab
Please check if the hard drive comes with small wire bridge inserted in master pins (not in slave or cs) all the disk come with three diff posisions, for this small bridge comes in colours black , white or blue. in ide hard disk.
after that please goes the computer to setup F2 and start in boot seccion and active only ide cdrom ( please don't use a hard drive or floppy options.) other systems with f12 and u can star with cdrom and insert the operating system(windows 98, Xp or vista and the machine starting the load againg. please check step by step for replace the missing information.
May 17, 2008 | Western Digital Caviar® WD300AB 30 GB...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
