Question about Zoppini Black Oval Face Stainless Steel Watch
I have lost the back cover of my watch. Had a new battery put in and the first time I wore it afterwards , I noticed the back covering was missing. Can you send my a new back or advise where I can a
My Zoppini Balck Oval Face is just like the one pictured with Zoppini charms. I have lost the back covering. Can you replace? Pat
  • 109 Answers
Alot of times the company will help you with this problem, get ahold of them first. If you have no luck there, fined yourself a reputable watchmaker who probibly will be able to fit one on for you. You are lucky it is a round back,any other would probibly be near imposible to fit. If you still have problems let me know . I have been a watchmaker for 24 years, my father was a watchmaker for 50, and my grandfather was a watchmaker for 50., between what I have gathered in 24 years and my family, I should be able to help. Good Luck!!
Posted on Aug 04, 2008
Removing back of irish collection ladies watch for new battery
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...Missing: irish
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
Sep 1, 2011 - Uploaded by RichsMethods
I also show how to polish the metal portions of your watch. ... of how not to take the back off and remove ...Missing: irish
Dec 21, 2015 | DG Watches
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 | Watches
I have a womens Columbia watch that is also water resistance to 65 meters. The battery has gone dead and I would like to replace it. Most watches have a groove to pry the cap off. This watch does not have...
mcdevito75 here, Hello Traudl, I see what you mean by not seeing or haveing that little tab on the back cover to pry off the back. I'm not an expert but do know a little about watches. Look again for this tab on the back cover, use a magnifier glass available at all Dollar stores to see this tab. Of course you may be right and there isn"t a tab, in that case look carefully between the back cover and the case of the watch for a cutout, it should be somewhere between the back cover and cvase of the watch, it"s very easy to miss this is why I suggest the magnifier glass. If by chance the back cover has square holes going around it"s circumference, then you would need a special tool to unscrew this back cover, I don"t think so though. If all this fails then your best bet is to look for a small watch repair shop in your area for a new battery. Hope I've helped.
Sep 13, 2010 | Columbia Watches
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
Replace a battery cover in a guess watch
Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
which take lots of time try expert watchmaker hope you get it fix.
even thought it fix some time it's lost capability to keep your watch save from water.
hope this info help
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Oct 01, 2009 | Guess G85675G WristwWatch
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
Casio Databank 150
If your databank is like mine (DB-35H), there is a TINY spring in a really unusual spot that you probably didn't notice that fell out. Laying the watch face down and with the back off, there is a little tiny hole in the back towards one of the corners. (sorry, already put my watch back together and didn't notice which corner.) There is a tiny (1/16" x 1/4") spring that sits upright in that hole. It must make a contact with the metal cover. I replaced my battery and when I did, a spring fell out. I looked all over the internet, then wrote Casio, who said they didn't have access to the information about where the spring went. (Doh!) I got a used DB-35H from my brother and was going to swap the innards when I noticed the spring on his. Put my spring back and it beeps! If you've lost the spring, don't know if you can fake it with tinfoil or not, but it really is a TINY spring. Good luck.
Mar 26, 2008 | Casio DBC1501 Wrist Watch
Restarting after battery change
My watch stops and when i try to wide it again it won't restart. I also do not have a battery in my watch. Please help!
Nov 04, 2007 | Watches
Zoppini Black Oval Face Stainless Steel Watch Logo
904 people viewed this question
Top Zoppini Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Zoppini Watch Expert? Answer questions, earn points and help others
