Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
I have a Husqvarna YTH 150 riding mower probably 10+ yrs old. The plastic tube from the cutting mechanism to the 2 bins on back needs replacing. It is on the right side of the mower.
    Brigadier General:
  • 3,911 Answers
I guess one could do a google search for "husqvarna mower parts", that brand is really made by AYP so you may want to search that too. When you search you get links to sites selling that stuff, you look at their web pages and see if they have want you want, if not then go to another link and hone your search.
Frankly what I would do is take the plastic pipe to a small engine/mower repair shop and ask them where they would find a piece of pipe to replace it. It most likely does not need to be clear, so about any like diameter plastic pipe cut to length would do and would be much cheaper than trying to track down and pay for an OEM part. Hardware stores often have various sizes of that stuff laying about to make into drain and sewage systems.
Posted on Mar 30, 2011
Husqvarna riding mower engine dies when you engage blades
Check engine revs are to low and pullies underneath not seizing up.
Aug 16, 2014 | Husqvarna Yth 150 Riding Mower Illustrated...
Husqvarna mower
you have something hooked up wrong,they should not be near the spindles,is it on backwards?, http www searspartsdirect com model part yth2042 3199 1509200 p0804135...
Jul 07, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna yth 170
What size motor and edge is Husqvarna YTH170? What is the price reasonable?
Mar 27, 2013 | Husqvarna Riding Lawn Mower 42 Inch Cut...
What type of fluid goes in husqvarna yth 150?
Hydro gear box takes a sae 20w 50 motor oil, Tuff Torq takes a sae 10w 30 motor oil
Oct 20, 2012 | Husqvarna Yth 150 Riding Mower Illustrated...
What's your problem? Husqvarna YTH 2148 can't find the oil drain plug
the trans doesn't have one the engine has a black tube coming from he side you push in and turn the outer sleeve add a hose to the nipple and drain it out the might be a small yellow cap in the end of it
Aug 17, 2012 | Husqvarna Garden
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
Husqvarna riding lawn mower yth 2448 cuts off as if running out of gas after 10 - 30 minutes
Mine would run for about 15 minutes and die. I pulled the carb off and thoroughly cleaned it. Inside the float bowl there is a plastic device held on by two phillips headed screws. Under this device are two tiny tubes with small holes in the side of them. Make sure these are clean. I used carb cleaner in a spray can and a tip cleaner. Make sure to wear eye protection if you use spray cleaner. I reinstalled the carb and, so far, it is working fine.
Apr 08, 2012 | Husqvarna Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
139 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
