Question about Sony VAIO VGN-S460 Notebook
Laptop won't turn on
My laptop won't tun on. It died yesterday without warning while it was plugged in. It's about 1 1/2 years old. Would the problem most likely be the battery, or the power supply?
    Guru:
  • 257 Answers
Anyway firstly check removing the battery and plug to a well functioning socket to power supply and test it yourself if it works and if it doesnt then post to me what happen after that and again does it brings light to know if it sees the battery at all if it sees the battery then try charging it for hours ok .
Posted on Sep 05, 2008
Hp pavilion dv3
It looks like there is a short somewhere inside the laptop. Could be the mobo, or just about anything else connected to the power supply.
Try disconnecting the power connector on the mobo, then try plugging in the power plug and see if the light still goes out. If it does not go out, then the problem is the mobo. If not, then somewhere else. Try disconnecting the power from one component at a time to eliminate the various components. Also look for wires that are shorted together or connectors that are inserted improperly.
May 14, 2014 | Computers & Internet
Laptop shuts down when using battery
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 31, 2012 | Compaq Presario Notebook
Dell inspiron said battery low plug into charger, when plugged in charger light goes out and laptop will not power on, why?
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
Mar 24, 2012 | Dell Inspiron N5030 Notebook PC
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Computer shuts down without warning
My first guess is that your laptop is over heating. Even with a fan underneath, if the bottom vent is clogged with dust, the CPU will still get too hot. Does your computer last longer when you run less programs? I would check for dust around the fan inside your laptop. There's a video on youtube showing an acer being disassembled:
Although it may not be your laptop specifically, hopefully it will head you in right direction. It would be a bad idea to blow the dust further back into your computer, so you may have to loosen some screws and buy a electronics duster from an office supply store, but it should solve the problem. I've ran into this a lot over the years, specifically with Acer and Dell computers. Hope this helps!
Jul 14, 2009 | Computers & Internet
When I turn on the power to my laptop, tries to turn on but dies
According to me, you should check your power adapter. I think it is not working and is not producing sufficient power supply for your laptop. And due to this, your laptop have not been charging.
Jan 17, 2009 | Intel Motherboard
My Hp laptop battery showing red color and the condtion is not good
How old is the laptop? If it's older then 1 year it's just getting old. I recommend taking the battery out when it's plugged in for long periods of time. Batterie's that are being charged all the time will die faster, of course this wont help you now, but for future ref. I hope this helps.
Nov 17, 2008 | HP Computers & Internet
Dead battery
you need the ac adapter to charg the battery
Apr 25, 2008 | HP Compaq Presario V6105NR Notebook
Sony VAIO VGN-S460 Notebook Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
