Question about Samsung SC-A30 Camcorder
C.emg. chewing tapes - Samsung SC-A30 Camcorder
How do I stop the vcr chewing tapes?
Probably bad drive belt need replacing.
Sep 18, 2014 | Televison & Video
When tape is loaded into camcorder the tape gets chewed up - there seems to be damage to the casing
This can be due to a faulty PINCH ROLLER as it can chew if the bearing are worn out . If so this must be replaced, Also a faulty mechanism, links , alignment can make the tape to move out of the track and get chewed.
finally the tensioner of the tape which is tension band can be faulty and so it will allow the tape to be loose to get chewed down.
Jul 27, 2011 | Panasonic 5 PANASONIC MINI DV 60 DVM60...
Tape chewing
use a vcr cleaning tape.
Feb 18, 2009 | LG XBR446 DVD Recorder/VCR
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
There is a tape stuck in my camera.
there may have been a spring that pulled on a tab in these places that will unlock the the tape , and if is not unlocking it will go back to close position
Oct 24, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
What do L.EMG and R.EMG mean and why do they prevent me from any activity with my camera?
Hello, The errors you are getting are "reel" errors. One or both of the tape reels are not turning during tape movement and the camera is shutting down to protect itself and your tape. In this model this problem is usually caused by the take up reel shaft being bent due to improper insertion of the cassette although this may not be the case. Please inspect both the takeup and supply tape reels and insure they are in correct alignment, if not, a gentle push to one side or the other will place them back in operating position. Good luck to you. Joe Weibel CustomElectronics.Org
Apr 22, 2007 | Samsung SCL901 Hi8mm Camcorder
Display reads R.EMG
The belts that drive the tape are most likely defective.
Apr 11, 2017 | Samsung SC-L906 Camcorder
Error messages
Any of the following Error Messages "D.EMG, C.EMG, R.EMG, L.EMG" indicate a mechanical failure in the camcorder. The following steps may resolve the issue. 1. Eject the tape 2. Set to OFF 3. Detach the battery 4. Reattach the battery
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung SC-A30 Camcorder Logo
61 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
