Question about Frigidaire Refrigerators
Refrigerator door warped? condensation inside
- has been almost raining inside. We thought it was a seal problem, but maybe the door itself is warped.
  • 481 Answers
Pull the door seal back and look behind it. if you see 1/4 inch screws every 6-8 inches then you can re-straighten the door.
  • take the door off of the refrigerator and remove the handles
  • lay it down on a flat surface, like a large table or hard floor (not carpet)
  • loosen (dont take out) all of those screws behind the door seal. this should relax the metal part of the door so you can twist it and make it flat against the floor.
  • once it is completely flat on the floor on all corners then tighten all the screws, starting with the center of each side and work towards the corners.
  • when you reinstall the door make sure you line up the door correctly before tightening the hinge bolts.
Posted on Aug 04, 2008
SOURCE:
Why would my floor board on the drivers side have a puddle of water? I did just replace a heater core. i thought that would solve the problem.
So you're saying you replaced the heater core because water was puddling on the driver's side, but water is still puddling on the driver's side? I'm assuming you're in the US and the driver's side is on the left and the heater core is on the right side.
Do you get much rain where you live? Is the vehicle parked outside? Do you notice the puddling more often after a rain? If this is the case, your water intrusion may be because of a leaking seal around the windshield or door. Check by getting the floor reasonably dry, and then have someone sit inside while another floods your car with a garden hose - specifically the windshield and driver's door. Have the inside observer try to catch a stream of water along the edge of the windshield, along the door jam, or along the door sill.
Dec 08, 2016 | Cars & Trucks
Electrolux Built in freezer door not closing.
I'm suspecting the door also because of the lack of suction power. you have to check the gasket more. Frost around the door is a great indication of where warm moist air is coming into it.
Aug 14, 2013 | Refrigerators
I have a antifreeze leak on a 2003 ford sports trac
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e4058#hd1-1-1 Hi Donna,here's a link to the water pump diagram,is the mating surface that the gasket goes on clean and not badly scraped up from removing gasket,the pump itself is aluminum and could be warped and not sealing good causing it to leak,maybe you need a new water pump,hose on that side isn't leaking?
Oct 12, 2012 | Ford Vehicle Parts & Accessories
Excessive condensation inside.
check the door seal is sealing properly and if the seal is broken,if the seal is broken it will have to be replaced
Sep 04, 2012 | Jenn-Air JSD2695KES Side by Side...
Condensation inside refrigerator
check the doors to make sure that they are level and that there are no spaces in between the gasket and the body of the machine. Also check the door seals themselves. Your getting condensation because you have warm air getting in somehow and clashing with the freezer air and causing the water to form inside
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Amana Refrigerators
I have a 2004 Chevrolet Avalanche when it rains water comes inside the cab somehow carpet is soaked on drivers side and speakers on drivers side front and back will not play. Any idea where the water...
Check the seal around the drivers door. Try to determine the level of saturation as you move your hand from the door to the center console. If it is wetter closer to the door, this would indicate the door seal of the door window seals are damaged and need replacing.
May 25, 2011 | 2004 Chevrolet Avalanche
Rain comes in on the drivers side floor of my 2001 mercedes 320ml only. Is there something left open causing this???
If you have had the windscreen replaced or the drivers door repaired it is possible that the windscreen hasn't sealed properly or the plastic weather sheet that is covering the inside of the door behind the interior door trim to stop the rain from entering the car has been removed and the rain is coming in behind the door trim and into the car.
The only other thing I can think of is the actual door seal around the door opening is not sealing
I hope this helps
Jan 01, 2011 | 2001 Mercedes-Benz M-Class
The driver side floor is wet under my feet thought maybe it's leak in window just on floor and only on driver side Thanks ron 2005 explorer xlt 70,000.00 miles
it might be a door/ windor seal or it could be a heating component leaking. im sure that the heater core is on the passenger side but when they begin to leak they cause a localized leak much like your description.
Dec 27, 2010 | 2005 Ford Explorer
I have a model ET8WTMXKO0 that has excessive condensation on the back wall, that fills up the bottom of the refrigerator with water after a couple of days. I thought it was the ice maker at first and shut...
Door seals not sealing out air. Or maybe a defrost drain that's clogged. If the defrost drain is clogged, there will most likely be a sheet of ice in bottom of freezer.
Oct 31, 2017 | Whirlpool ET8WTMXK Top Freezer...
Refrigerators Logo
1,304 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
