Question about Acer AL1706AB LCD Monitor
"input not supported" error on
  • 11,361 Answers
Http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 29, 2011
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
When i'm playing games in my pc, they run fine.. but after a while like 5min the monitor goes black with that rectangular box saying "Input not supported" i have an acer AL1916W and an AMD...
Update your video car drivers and then look for the specific drivers of your monitor, it happened to me once using windows 7 i just installed the monitor's driver from the manufacturers website. go to acer website and support download page and search for your model, donwload and install and hope that solves your problem.
Sep 06, 2011 | Acer AL1916W 19" LCD Monitor
Acer AL2216W 22" LCD monitor. DVI
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Acer lcd al1706 a monitor hooked to hp pavillion laptop and previously it worked great but i disconnected it to move and now reconnect and all plugs are fine and connected but monitor says "no...
You should try this monitor and the video cable with another PC to see if it works OK, or try this laptop with another monitor to see which one is not working, I have a feeling something has changed in the laptop setup.
Please post back what you find.
Jan 15, 2011 | Acer AL1706AB LCD Monitor
I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 10, 2010 | Acer AL1706AB LCD Monitor
I have an acer al1706 lcd monitor. it won't turn on. the power light is blinking every 5 seconds.
This is generally indicatve of bad capacitors in the circuits. Take it to a reputable repair person or check my website www.micromendllc.com
Feb 25, 2010 | Acer AL1706AB LCD Monitor
Acer al1706a driver
Just try here : http://www.bioticaindia.com/al1706.html .
If that didn't work , then get back to this website http://support.acer.com/drivers_download.aspx
and try the nearest numbers to your monitor series for example AL1702 or AL1703 or AL1711 .
that works in the most times believe me .
good luck
rate if that was useful please !
Jan 30, 2010 | Acer AL1706AB LCD Monitor
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Acer AL1706AB LCD Monitor Logo
220 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
