What is error F7 on a gorenje WA72145BK washing machine?
    Brigadier General:
  • 6,277 Answers
Gorenje's 'F7' decodes as 'pump fault' (drain pump).
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 28, 2011
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
Washing machines
/manuals/_washing_machines/gorenje.html
you can get the item you need here good luck
Jan 12, 2014 | Washing Machines
Gorenje wa72145bk erro f2
it your door lock that faulty
Jul 01, 2012 | Washing Machines
Gorenje WA72145BK fault 6 displayed on my LED
I have the same problem. Any solution? Thanks!!
Dec 12, 2009 | Washing Machines
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
I need schematic diagram for gorenje wa 50050 washing machine
I find a schematic diagram on internet address www.masine.sigma-com.
Thank you for trying!
Jun 29, 2009 | Washing Machines
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Washing Machines Logo
7,630 people viewed this question
Top Washing Machines Experts
