Question about Maytag Washing Machines
Maytag Maxima front-loader. new washer, never used. stops 5 min into wash cycle and displays E01 + F08 error codes alternately. Pressed STOP (twice) to clear error codes per manuel. Codes cleark, washer starts, then shuts down completely. This happens on all cycles except "Rinse only/ Spin".
ZJLimited
  • 17970 Answers
SOURCE: error code e01 f08
Knowed as F8 E1 error code...
This code indicates there maybe a problem with the water supply to the washer. Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; you can find them by entering your model number in the search tool below.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent? Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
To remove the error display, press Power once. Then press Power again to restart the washer. If pressing Power does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTES:
* On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
* If the error remains on the display, and all of the other conditions above have been checked, call for service.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Oct 26, 2011
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
pride applia
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Water will not enter drum
not sure bout ur error code but would check the water inlet valve and the water pressure switch
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Throwing code E08. How do I fix it
I Googled my washer to look up some stuff i couldn't find for my own washer other than here and i did not see E08 as an error code in my manual or on any of the other websites but i did see F08 followed by E01 which was a water supply error:: and you have to check for proper water supply:: check the hoses and the faucets to be sure that the screens are not clogged and the hoses are not kinked to clear the code touch the power button once then touch the power button again to restart the washer if the code appears again the manual says to call for service to send out a service tech.
Jan 09, 2014 | Maytag MHW3000BW Maxima X Front Load...
Maytag Maxima washer error codes E01 F08
Mine was resolved after changing the Symmons slide valve at the inlet to the hoses. This valve is spring loaded and does not work if not exercised as open and close on regular basis. My hot water supply was completely shut off and cold water remained open at all time. Check the incoming water pressure by unscrewing the hoses from washer and check water outlet by filling the bucket from both sources. Symmons slide valve at the wall is W-400 and was 25 years old.
Aug 16, 2012 | Maytag Washing Machines
Washing Machines Logo
3,174 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
