Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
I am welding 19 gage steel. WHAT DO I SET THE MACHINE AT. Seams to burn hole before start my pass
  • 194 Answers
You want to set the lever to DCEN and set the amperage at perhaps 40-45 amps (this will be the max when the pedal is fully depressed). I suppose we need to know what gas you are using but I would suggest using Argon. Sneak into the melting point - too few amps is not going to kill the job, so gradually depress the pedal until you find that magic combination of heat input and speed.
It would also be very helpful to know what tungsten you are using and at what diameter. I would suggest using 1.5% Lanthium or Ceriated Tungsten with a diameter of at least 0.50" but not more than maybe 0.100" ground correctly to a point. You can use a larger diameter but it might just get in the way of seeing. I use 1/8" for almost everything.
For thinner metal and for less experienced weldors, it's helpful to get the weld started away from an edge. Edges melt faster so less heat input is needed. It might take a little practice.
One weldor could weld 19 gage metal with a lot more amps than another so a lot of it is up to the experience of the torch holder.
Posted on Mar 28, 2011
Hole in stainless steel dishwasher tub... How can I patch it?
To make a permanent repair on stainless steel, it needs to be welded. If the hole is small & accessible from both sides, it can be repaired temporally by inserting a machine screw through a tight fitting metal washer, then a tight fitting washer; place the screw through the hole and install another rubber then metal washer on the opposite side. Tighten the washers in place using the proper fitting machine nut.
Oct 29, 2013 | Dishwashers
Burning through everything
Do you have a photo of the "burning through"?
is there gas coming out of the torch ?
Dec 23, 2017 | Welding Tools
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
Not forming a continuous bead on the inside of a 3'' carbon steel. set amps at 85/ 90 argon at 10, what am i doing wrong. please help me
I need more info, you are Way too vague.
What type of weld are you trying to do? A Fill weld?
Are you trying to fill a V in-between two pieces of hard steel, (Carbon), that is 3 inches thick?
1. If you are, the electrode should be held at a 90 degree angle to the metal. Straight up, and down.
Moving the electrode too fast will cause a intermittent bead. Slow down. TIG welding takes time. It isn't like ARC welding.
If the electrode burns off to one side, you don't have the electrode in the correct position.
2.Too little heat, (Amperage) will make a 'Cold' weld, and you won't have the penetration that you need. Too much gas (Argon) will do this also. Too little gas, and you'll burn through.
Nov 08, 2009 | Welding Tools
RE DOORS FAILING AT HINGE
Look at the hinges. If they are bolted and the only problem is they are loose. Try to tighten tem. A tig weld in place will burn odff any paint and if welded poorly you will have alignment problems. The welder will be welding heavy metal to sheet metal The bolts that hold the door on pass through a heavy steel threaded plat behind the sheet metal. Good Luck, Ned
Oct 06, 2009 | 1995 Jeep Cherokee
Helo i have a k2188-1 welder it burns rough metal and splaters i am new at welding so is it me or the machine i just got it
you will get a lot of spatter when welding. Especially if the metal is not clean. As far as it burning rough metal, I really don't have enough information to help. What do you mean burns rough metal? This particular machine is only rated for 1/8" mild steel. If you are welding thinner than that, it is a good possiblilty that you have your heat too high and the wire feed is not adjusted for your rate of travel correctly. These two things will and can affect the amount of splatter and if it burns your metal. Also your distance from the material to the gun and you also have to have flux core wire since this has no gas inlet to sheild your wire. Hopefully this information will help.
Sep 13, 2009 | Welding Tools
The seal of the dishwasher is broken and the spot welding on the stainless steel strip that holds the seal has pulled away from the tub.
use super glue to glue in place in spots cut away seal near the weld seams, then make sure the door closes ok then get 5 minute epoxy and glue the seal on where it comes off, it's a permanent fix for a old machine but it will work. so go ahead and replace the seal.
May 29, 2009 | Dishwashers
Starts welding good then doesent
Hi, This problem has happen to me, My solution was a grounding problem. Take your ground cable, and put it on the table leg.
If this doesn’t work for you, please write back. Thanks,
Nov 17, 2008 | Miller Welding Tools
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
135 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
