Question about Blanco 157-075R-BT Elan II Kitchen Faucet Biscuit
The aerator fell out of blanco elan II kitchen faucet.
  • 74 Answers
SOURCE: No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Posted on Apr 25, 2009
snap101
  • 117 Answers
SOURCE: low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Posted on Aug 01, 2009
  • 1584 Answers
SOURCE: Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Posted on Jan 26, 2010
  • 54 Answers
SOURCE: brand new faucet, on central aerator setting (not
Aerator ,sounds like it is not on right ,maybe cross threaded,or just not tight
Posted on Apr 13, 2010
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
Parts diagrams
I don't think you can unless it is a part that you can order. Check with your local hardware store and see if they can order just that part.
May 04, 2014 | Blanco ELAN II 1 Handle Pull-out Spray...
Blanco 157-075-WH: Any new faucets in stock?
Certainly not at FixYa as we don't supply any physical goods of any kind.
Just entering the term Blanco 157-075-WH on Google immediately produces results, such as this one, but it all depends upon where in the world you are. FixYa is a globally available website so without knowing which part of the world you live in it's difficult to suggest a relevant stockist.
Sep 16, 2010 | Blanco 157-075R-WH Elan II Kitchen Faucet...
Remove water saver device from Blanco Grace kitchen faucet
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
How do I remove the aerator on a moen pull out kitchen faucet?
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Jan 27, 2010 | Blanco Classic Single Handle Faucet with...
Faucet is getting tougher to move in all
there is an allen key that holds the handle on this is located under the hot cold indicator.take the handle off ,unscrew the housing an pull the cartridge out,try to shake out what ever is in there,you may need to replace the cartridge,you can get this at any place that sells plumbing supplies.hope this helps.good luck with your project
Jul 29, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Blanco purus II poor water pressure
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Jan 30, 2009 | Blanco Plumbing
Blanco 157-075R-BT Elan II Kitchen Faucet Biscuit Logo
143 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
