Question about Canon ZR830 Mini DV Digital Camcorder
Won't play on TV
Hi-- I purchased a used Canon ZR830 camcorder that did not include an AV cord to hook it up to the TV. I ordered one of the internet that was said to be compatible. I can't get movies that I have recorded to play on the TV. Nothing at all. Have tried more than one TV. The AV cord seems to fit fine but not sure what the issue is. I was also provided with the original USB cord but no software. I tried to plug it up to my computer just to see if it would recognize anything but it didn't. I guess that could be because of the lack of software but still doesn't explain why they won't play back on the TV.
Thanks
  • Canon Master
  • 2,794 Answers
Some of those av cords are wired for use on Apple computers and the leads into the mini jack are either reversed or they don't line up properly. The best way to get it fixed is to bring the camera into Radio Shack and test the correct cable that you need. You can order one from Canon usa website as well.
To get the USB connection to work requires software to run it. Pinnacle Studio works well with that.
Posted on Aug 04, 2008
No luck hooking video camera up to TV - no picture
have u checked to see if the camera is PAL or NTSC? If your TV is one and the camera is the Other, then chances are you will not get a picture.
May 12, 2012 | Canon MV630i Mini DV Digital Camcorder
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
Playing camcorder video on TV
Hello there. The only way to hook up your camcorder to the tv is if you change the settings of your camcorder. Every camcorder has a different setting menu so you might just have to look it up in the manual. Or maybe your cables are not connected properly.
Dec 16, 2008 | Video Cameras
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Camcorder not recognized
You need software to recognize it. Do you have video editing software in your computer?
Jun 30, 2008 | Canon ZR830 Mini DV Digital Camcorder
Not showing on tv
A-V Cord is one of the reasons, not showing picture on TV. Try to hook up cord properly or use another same cord.
Jun 04, 2008 | Sony Handycam CCD-TRV108 Camcorder
Export movie from an older TRV68 to computer
I purchased a canon elura 100. The 100 has a AV -> DV converter. This allow you to tunnel your Sony via a 3.5mm 4-pole mini AV to mini AV camcorder A/V cable to your computer.
Sony (via AV out) -> (AV) Canon -> PC/Mac (DV) via fire wire cable
Feb 12, 2008 | Sony Handycam CCD-TRV68 Camcorder
AV jack
YES YOU MAY EITHER WANNA REPLACE THE AV(STEREO VIDEO CABLE) OR IF U HAVE HAD IT LESS THAN 90 DAYS CALL CANON FOR A REPLACEMENT 800-828-4040
Nov 30, 2007 | Canon DC100 DVD Camcorder
Xbox 360 Premium
You should have received the lead to plug into your TV you should also have a lead to plug into your PC monitor plus power lead and brick. The lead for the computer monitor would be the lead you need to play on an HDTV. Please rate if useful, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon ZR830 Mini DV Digital Camcorder Logo
137 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
