Question about Cameras
I recently bought a Nikon EM camera. The first time I used it worked well but The second time when I took the film to be developed, no photos came out. Now I'm noticing that the film door is not closing properly. Is there any way to fix this without incurring in huge expenses?
  • 747 Answers
Without seeing this, I can't really tell it might be that the rear door is slightly bent OR the light seal(s) are preventing the door from closing properly.
When you close the back on the camera it should close without force or pressure to latch, should be a nice crisp click. If once you have the back closed and you cn pinch down on the bck and it moves inward towards the camera then the seals are worn out and need replacing. This isn't a huge job it's one of the more common things with a film camera. I'd say probably a $60.00 fix depending on where you are and most camera repair shops do this.
There could also be several other things that caused the camera to not expose one being the battery could be exhausted (dead) and requires a new one (cheap and available) another is the aperture blades in the lens could be stuck open.
Have a service person check it out before loading more film
Posted on Mar 28, 2011
35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Sep 03, 2009 | Photography
White shadows on my negatives
Is it possible you are somehow putting a finger in on one side when you are holding the camera?
If not, maybe there might be something wrong with the shutter blades not fully opening. Good luck.
Aug 05, 2009 | Nikon EM 35mm SLR Camera
Nikon EM (1979?) Won't wind film, photos don't come out
Not necessarily. The EM has an M90 setting which will fire the shutter at 1/90th of a second. The meter is inactive on this setting. It was put on the EM so that if the batteries fail, you can shoot at 1/90th and take a guess at the exposure. There is also a small button (blue or chrome, depending on the production run) which lights up a red LED if the batteries are good. The light meter doesn't work until the frame counter is at 1 or higher. Before the #1, the shutter will always fire at 1/2000th of a second to speed up the film loading process. You can tell that the meter is working by observing the meter's scale/needle on the inside of the viewfinder. If it is pointing out of the red zone, it's OK to shoot (proper exposure). If the needle is in the red zone (indicating under or over exposure) the camera will "beep" as an audible warning. Check the battery condition first.
Mar 16, 2009 | Nikon EM 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Nikon EM film winding lever is stuck. Can I repair this myself? Purchased at a yard sale with loads of lens and worked great for about 7 rolls of film. Shot part of a roll and lever refused to advance...
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
Nov 22, 2008 | Nikon EM 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Developing film
You need a whole bunch of chemicals, paper, equipment and some kind of dark room, plus an enlarger. This is all quite expensive, I suggest you concentrate on figuring out how to take the photos for a bit before you learn to develop your own.
May 24, 2008 | Nikon N75 35mm SLR Camera
Horizontal lines on image
This is not a solution , but only a work around. If you do at least 1/3 zoom on your lens before clicking a photo, these lines will not appear. But this not not a convenient way I agree.
Also this surely means that the CCD is not the problem otherwise it would have never worked ( electronic parts cant simply dont start to work when you zoom ringht ? ). Surely Nikon is fixing the issue, but cheating the customers by charging for a part is not defective in the first place
Nov 22, 2007 | Nikon Coolpix 8700 Digital Camera
Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. frankvos@sasktel.net
Oct 07, 2007 | Nikon One Touch Zoom 90S 35mm Point and...
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
