Scanners im trying to find out how to program a scanner I can't get my scanner to scan Bank 5 of the programmed frequencies. Lost the instruction book. Please help. Thanks.
  • 53 Answers
What is the make and model of the unit ?
Posted on Aug 07, 2008
How do I program a BC155XL scanner?
I can't find a manual for this oldie, but generic Bearcat programming may work:
1. Press the MANUAL key to select the channel that you wish to program.
2. Enter the desired frequency, including decimal point.
3. Press the ENTER or E key.
4. Repeat the process starting with number 1.
Mar 25, 2009 | Delphi Roady SA10035 XM Radio Receiver
Owners manual for a uniden bearcat bc560xlt scanner
manuals can be found at amazon, click here and take a look: Amazon com john deere lt133 manual. I hope this was helpful. Cheers
Feb 03, 2009 | Audio Players & Recorders
Cannot set fm frequency on radio
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
Jan 01, 2009 | Sirius Satellite Radio Receiver
No setanta on 5401
I had this problem so i scanned them a few times and they sorted them self's out . another alternative is finding any particular channels or are missing. i have tried this also.
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? ,the ?? being 2 digits.
Using this method my indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
I also gained a few extra channels.
The other transponders may have been picked up by scanning other providers. if no luck let me know .
Dec 08, 2008 | Audio Players & Recorders
I would like police scanner frequencies for ventura co ca 93002
What type of scanner do you have? Is it strictly VHF, or does it have UHF also, does it cover the Marine band? I am not that familiar with Ventura County. FYI...Most of the police & sheriff Depts in the US Use Starnet which is Satalite based. That doesn't mean that you can't pick up on the transmissions. When the system get over worked it returns back into a trunking system and it is then that you can pick up the transmissions. The problem is that many times the transmissions are random and you may hear the first part of the call and then it may go to a different call altogether. At any rate there are other transmissions that you can hear such as airport towers, Flight Controllers, Misc Govt services, sometimes the fire and rescue (depending on your area) and sometimes you can even pick up the ISS. Here are a few links that might help.
http://www.radioreference.com/apps/db/?ctid=238, http://www.spconnect.com/~michael/scan0794.html
http://www.scannerstuff.com/scfd_Ventura.htm
http://www.soundisgood.com/scanner/venturafreq.htm
http://www.nationalradiodata.com/?gclid=CMbQrpfP-JYCFQKaFQodbAbkXQ
http://www.angelfire.com/ca3/glowdark/VCSCAN.html
Best wishes.......Mike
Nov 14, 2008 | Audio Players & Recorders
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Cobra-sr900 reception
Press E after the Channel # instead of manuel.
May 27, 2008 | Audio Players & Recorders
Digital codes
Where did you get it?
Warrenty?
check at Radio Shack for replacementcode list...
May 08, 2008 | Audio Players & Recorders
Cobra sr 900 scanner
Get a 12 volt cord from Radio Shack.
Jan 18, 2008 | Audio Players & Recorders
66 people viewed this question
 Grubhead
Grubhead
