Question about Nokia N80 Cellular Phone
Nokia N80 "memory low message"
I have deleted practicly all the data files on my Nokia N80, and I am still getting a message " Memory too low to recieve messages" I have deleted all the music files, all photos, videos and images, and several of the applications such as quick office and timezone updater. My phone memory still has 1900MB of free space on it, and my memory card has even more. What am I doing wrong? I am running out of things to delete, HELP!
Angie Sheeley
angiesheeley@hotmail.com
I don't know if there's a certain part of the memory reserved for messages, but that could be the problem. You've mentioned that you've deleted lots of things, but not mentioned deleting messages. If you've not deleted all of your received messages, give that a go and then switch the phone off. Switch it back on again and hopefully that'll have done something.
Another idea would be to clear the cache in the browser, which can hog up lots of free space after a while.
Hope one of these might help.
Posted on Aug 06, 2008
I'm having this problem in my nokia e5 : My memory
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Cell Phones
I have a nokia c5-03 and i get the message:not enough memory to perform operation.delete some data first but i cannot enter anywhere(in settings) or application manager,etc because i get this error. also...
I hope this helps!!
Aug 06, 2017 | Nokia Cell Phones
When i open my n72 any file it show memory low delete some data
hi,
you must delete unimportant files from your phones memory or else it will crash soon.
it will need sufficient memory to process data. instead, save your files on your memory card.
most files that uses big memory spaces are the videos n mp3's. you must delete some of that.
message me if you have more questions.
Don't forget to rate me. Thanks...
Regards,
john
Jan 11, 2011 | Nokia N72 Cellular Phone
"Memory low. Delete some data from phone memory" message comes frequently. I have nothing installed on phone. Even I can't back up in PC suite
Yes may be you have not installed any application.But check message folder,contacts in phone memory,the files in gallery,which are located in phone memory,check memory status in file manager.etc If you found delete it or make back up to memory card.Lastly,check the memory card because the inserted memory card might be exceeds to the instructed expandable memory.
Aug 13, 2010 | Nokia E71 Smartphone
N73 Cellular Phone: my nokia n73 memory low delete some data sir what ...
This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows
"memory low delete some data"
So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73
Which can be downloaded Here
Or else use Phones inbuilt file manager to delete unwanted files from phone memory.
Hope this will solve your problem
(Alternate download Path Click HERE)
May 16, 2010 | Nokia N73 Cellular Phone
Phone memory is running low. it says i have 14MB in the Messages folder. I erased all my messages but still the memory is so low. how can i solve this?
The messages that you have deleted were in our sim card memory.. You need to delete data from your phone memory.. Go to gallary and delete some data from there (phone memory).
Jul 11, 2009 | Nokia N72 Cellular Phone
How to delete some data in my nokia n73?
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone !
and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
It rockx.
Thanks
Apr 09, 2009 | Nokia N73 Cellular Phone
Memory low delete some date
Memory low : delete some data This is the error message that appears in my N73 mobile once in few days. There will be no space for new messages and no messages can be sent at this time. But the good news this error text will not be present in the mobile for more than a day and the next day every thing is all right. Its just like a viral fever i think, comes and goes with no treatment required for recovery. Here are some tips which can help you to come out of "Memory low delete some data" virus in your mobile phone especially nokia
Do's
-i think this is the best one
the reason for this is lifeblog, u can find that the file lifeblog.db will be the file that has increased its file size and causes this error, just go to lifeblog-settings-item types-and uncheck all the files here, after some time the memory will be normal
-delete some files in your phone memory so that you keep receiving the new messages(your phone memory will be very less at that time)
-try to close all the applications by pressing menu button for some time
-switch off the mobile and take the battery out and then insert it back and switch on
-after you regain the memory in your phone put some files in it like a song or other files so that you can delete in the emergency times
-be patient this situation comes because of some error in memory console of your mobile and it will be solved without our interference
Dont's
-Dont get panic and step into Nokia Care for firmware update this will never help the cause
-Dont try to get any new anti virus as this will never solve
robinrichardrajan@gmail.com
Dec 30, 2008 | Nokia N73 Cellular Phone
Screen keep appear 'memory low. delete some data'
just change your prefered storage to memory card...actually your selected memory is phone memory...so thats why every file received from bluetooth save in phone memory..to change your stroage go to messages ------> settings-------> change your storage from phone to memory card....i can send you a detailed procedure if you want
Oct 10, 2008 | Nokia N73 Cellular Phone
N80
you must check memory setting,i think you use phone memory change to memorycard use in phone setting at memory status.about sim you must go to shop for more imformation.
Sep 12, 2007 | Nokia N80 Cellular Phone
Cell Phones Logo
106 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
