Question about Lexmark X4650 InkJet Printer
How do i use the scanner on this product? - Lexmark X4650 InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Please refer to this article in the Lexmark website on How to Scan Using the Lexmark X3600 & X4600 Series All-In-One.
Posted on Apr 06, 2011
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
I'm surching installation software for agfa duoscan
Agfa discontinued its consumer scanner product line (SnapScan, DuoScan, Arcus), as well as its digital camera product line (ePhoto, StudioCam) in September 2001. Therefore, we are no longer able to provide any support. Agfa does not keep digital cameras or scanners, nor spare parts for these products, in its stock. A number of companies (such as VueScan) offer drivers that should allow older scanners to work with recent operating systems.
The solution is to buy a new scanner.
Good luck
Feb 03, 2013 | Agfa DuoScan HiD Flatbed Scanner
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Driver Scanner 1248ub Driver for win7
Unfortunately, there is no compatible driver for win 7. THe Mustek support center says the following:
Scanners designed to work with older versions of Windows may not function properly after upgrading your computer's operating system.
If Windows® 7 is not listed on the product driver download page for a specific product, no support is offered for Windows® 7. Newer scanner products available will have support for Windows® 7.
Sep 24, 2011 | Mustek Scan Express 1248UB Flatbed Scanner
MY HP 8500A HAS STARTED PRINTING WHOLE PAGE BARCODE LOOKING LINES WHEN I PRINT OR COPY IN BLACK. COLOR LOOKS GREAT. IVE CLEANED THE PRINT HEADS AND ALIGNED THEM. ANY OTHER OPTIONS? THANKS
Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
  3. Lift the scanner lid. Figure 3: Lift the scanner lid
  4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
    CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
  5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
  6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
  7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
    NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
  9. Close the scanner lid.
  10. Reconnect the power cord to the rear of the product.
  11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  12. Try to copy, fax, or scan again.
Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove any documents from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
  6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off the separator pad.
Aug 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
After printer is on for a few minutes, getting error message-scanner failure turn printer off then on again. I am able to print before the error message appears, however, unable to copy or fax. Thank...
  1. Follow these steps to check the scanner light by making a color copy of any document.
  2. Load plain white, unused, letter size paper in the paper tray.
  3. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  4. Make a color copy.
  5. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
  1. Press the Power button to turn off the product.
  3. Press the Power button to turn on the product.
  7. Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
  8. Press the Power button to turn on the product.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet D135 All-In-One InkJet...
Cannot find a download for a widows vista for hp scanjet 6300c
your operating system is not listed above, HP does not have software or driver downloads available for this product in that operating system. Your product pic00777.gif » HP Scanjet 6300c Scanner (Not your product?) icon_alert_sm.gif s.gif Alerts for this productNo alerts at this time That's pretty clear. HP doesn't support Vista on the 6300c Carl
Feb 12, 2010 | HP Scanjet 6300c Flatbed Scanner
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
I need driver for mercury scanner 1200 clim
You have not provided complete model info. The following is a list of different scanner models in 1200 series. Click on the link which corresponds to your scanner model. On the page that opens link for the driver is available.
Mercury 1200U Scanner
USB Interface Scanner, 48 bits Scanner, 1200 x 2400 dpi opticalresolution, 19200 x 19200 dpi maximum resolution
URL: http://www.mercury-pc.com/product-detail.php?productid=141 Mercury 1200U Scanner
URL: http://www.mercury-pc.com/product-detail.php?productid=675 Mercury 1200CU+ Scanner
URL: http://www.mercury-pc.com/product-detail.php?productid=750 Mercury 1200U Scanner KOB 1200U
Downloads
URL: http://www.mercury-pc.com/downloads_list.php?productid=675 Mercury 1200U Scanner KOB 1200U - new
Downloads
URL: http://www.mercury-pc.com/downloads_list.php?productid=141
Nov 27, 2009 | Umax Astra 3450 Flatbed Scanner
I have a vertical black line on the right side of my copies
Go to the HP website and read their solution. Here is what I found:
Issue When you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors. When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
Solution two: Clean the All-in-One and make a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass. Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01760887.gif NOTE: Your product might vary in appearance from the one shown in the figure, but the solution is the same.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner. CAUTION: Do not spray the glass cleaner directly on the glass to avoid damaging the scanner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01891674.gif Figure 5: Scanner lidc01891675.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid. NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  7. Reconnect the power cord to the product, and press the Power button (c01892763.gif ) to turn on the product.
If the copy is clean, there is no need to continue troubleshooting. If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
Nov 21, 2009 | HP DeskJet F380 All-In-One Printer
Lexmark X4650 InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
