Dell computer runing Windows 2000. Getting a stop error screen which advises me to run CHKDSK/F to check for hard drive corruption. I was given the computer, so have no disc. Is it possible to order one from Microsoft and if so, how do I do it?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Turn the computer off. Wait 30 seconds. Turn it back on. At the beginning of the boot process press and hold down on the f8 button until the safe mode menu appears. Select command prompt from the menu. type in chkdsk/f at the dos prompt. If that doesn't work, type in scandisk from the prompt. If that doesn't work, type in cd windows/command and press enter. Then run scandisk.
    scandisk replaced chkdsk around the time dos 6.0 came out in 1993. Since then the chkdsk command has been phased out.
    Champion:
  • 232 Answers
THE EASIEST THING TO DO IS REINSTALL WINDOWS HOWEVER IF THE HARDDRIVES HAS SOME CORRUPT SECTORS THAT CANNOT BE REPAIRED WITH BASIC SOFTWARE TOOLS THIS OPTION WILL NEVER FULLY WORK.SINCE U WERE GIVEN THE COMPUTER U SHOULD TRY TO PURCHASE UR OWN HARDDRIVE WITH A NEW VERSION OF WINDOWS. THIS WILL SAVE U TIME AND MONEY.
Posted on Aug 04, 2008
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
May 01, 2013 | Dell Latitude E6500 Laptop
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
My Dell Inspiron E1405 is getting the blue screen of death before starting up windows xp. It has the stop codes 0x00000024 (0x001902FE, 0xF8C7E4D4, 0x0F8C7E1D0, 0x83622816) it tells me to uninstall any...
STOP 0x00000024, 0X0000024, 0X24 or NTFS_FILE_SYSTEM = this stop error means that your NTFS file system is corrupt and this is practically impossible to fix - absolutely everything on your hard disk is trashed. The only reliable way to fix that is to reinstall Windows.
Nov 02, 2010 | Computers & Internet
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
I get a Blue Screen on my computer and the following: *** STOP: 0x00000024 ( 0x00190203, 0x82D7F008,0xC0000102, 0x00000000 ) What does this indicate is wrong? Is it memory faults or what? This was a sudden...
If you have the original Windows Install disk, you can boot off of that, choose the Recovery Console option, and once you are in the Recovery Console, run "chkdsk /r c:". The error seems to be a file system problem, so running a chkdsk could help or isolate the issue further.
Sep 29, 2009 | Dell Dimension E310 PC Desktop
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Dell Laptop Inspiron 6400 - "Stop Error Screen" appearing
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
There are two ways,you might be able to fix it
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware).
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
