Question about Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator
The water coming out of the refrigerator tasks like mildew. So does the ice. We replaced the filter with a new Kenmore recommended filter (#9990) and ran 5 gallons of water through before drinking. It still tastes like mildew. The water from the sinks in our home taste ok, so it has to be a problem with the refrigerator, filter or something related. Please help!
  • 1073 Answers
SOURCE: our ice tastes and smells
install an odoer filter on the fridges main water line
Posted on Apr 28, 2008
  • 706 Answers
SOURCE: Bad water taste coming out of Refrig
Hello collado36.. I'll give you a few ideas of things to try.. First there a coffee scent in the refridgerator or freezer compartment when you open the door/s? If so, try emptying the fridge and wash everything with white vinegar and dry all surfaces with a soft cloth ( dish towel is OK).. air drying is OK but you don't want the food you removed to clean it to go bad.. Do you have any food in the fridge that may have been exposed to that coffee that may be 'out-gassing' that coffee smell?
The water comes into your fridge via an electrically operated inlet valve and is dispensed into the mold tray of your ice maker as well as the drinking water spicket. ( I am not sure if your model fridge has a reservoir to chill the water prior to dispensing but it probably does...but that reservoir should not be exposed to the inner refridgerator compartment nor should it pick up any scents or tastes from there either. )
In trying to diagnose exactly where the foul water is generated.. can you detach the incoming water feed line from the fridge and drain that into a large jug? Then check that jug for the same smell? If it only happens within the fridge then the white vinegar wash should help.. .if it also happens in the jug then your incoming water may be the culpret.
Another way to clean your water supply system to the firdge would be to detach the water supply line.. buy another length of flex water line with couplings.. and fill that section with white vinegar that can be forced thru the water system and clean it from the inside out.. if you do use this approach, make sure you flush teh system clean of any leftover white vinegar .. Hope these tips help you resolve your problem.. please get back to me if after you've tried these, they don't work.. Good luck..
Posted on Oct 14, 2008
  • 1122 Answers
SOURCE: ice tastes bad
need make and model number,i;ll get back with you-mike
Posted on Oct 15, 2008
  • 1462 Answers
SOURCE: water smells/tastes like freon
freon has no smell or taste and in any case doesn't get anywhere near the water. look elsewhere like your water supply
Posted on Nov 04, 2008
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
Why is the water on my kenmore refrigerator coming out so slow?
I do not know the unit but it sounds like the water filter has plugged. Just replace the filter and the problem will go away. The ice maker can fill very slowly and you would not notice it.
Aug 24, 2014 | Kenmore Refrigerators
Ice and water keeps coming out
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Feb 09, 2014 | Kenmore Elite 31 cu. ft. Grab-N-Go...
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
We have a 10 year old Kenmore Coldspot Refrigerator (it looks like model # 590 9990). It is leaking water from the freezer door. We turned off the ice maker to see if that would stop the leak but so far-...
look for all/any drain holes and blow out/syringe with clorine bleach ,then check door seals for any air leaks.water in fridge is mainly condensation from warm food/replacement air when you open door.
Jul 02, 2010 | Refrigerators
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
