Question about RCA Televison & Video
I have an OLD RCA G27400WK television (PIP). I have a dvd hooked up to it and have watched dvds on the television before but now the video isn't coming through on the television. I put new batteries in the remote but cannot get either of the two aux. video channels to show (allowing me to watch the tv). I do not have the manual for the television or the remote and cannot find them on-line. Is my remote or television dead or is there something I can do to "reprogram" the tv. As I said, I do not have the manuals and cannot remember how to do these things. Thanks.
oicur12
  • 31 Answers
SOURCE: pip and pop
It sounds like your other TV had 2 tuners which allowed you to watch 2 programs at the same time. You can still watch two programs, but the second one will have to come from a second source. See below for the possible combinations that the PIP/POP feature can be used by this TV.
Posted on Feb 17, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
  • 8 Answers
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
Posted on May 29, 2008
  • 11 Answers
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Posted on Sep 13, 2008
mistersony
  • 320 Answers
SOURCE: No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Posted on Nov 11, 2008
I've hooked up my dvd player to my rca television
Did the dvd Play? if yes, Maybe you have to select in the VIDEO mode on your t.v. not in the CHANNEL Mode. Because you cannot watch video in channel stations unless otherwise you have RF tuner. or the rca plug is faulty???? Try another rca
Mar 20, 2009 | RCA Televison & Video
Attempting to get PIP to work
The solution will cost around $300. You need a video to DVI, component, or VGA converter.
Feb 01, 2009 | Protron PLTV-32 Television
Toshiba 32A33 32" TV
Hook up a dvd player to the rca jack inputs, select "video" on tv.
Press "play" on DVD...
Aug 27, 2008 | Toshiba 32A33 32" TV
Pip and pop
Dec 27, 2007 | Vizio GV42L 42 in. LCD Television
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
RCA PIP
Put something else, DVD player, VCR or a second signal, into one of the other inputs on the unit and switch the PIP to watch that input...
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
