Question about Hotpoint WMA74 Front Load Washer
Drum will not empty - Hotpoint WMA74 Front Load Washer
  • Hotpoint Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 28, 2011
Why drum making noice when the cloths r in spin. but on empty drum it goes silently
Because the drum is out of balance with uneven clothes, or that the shock absorber springs are worn, broken or stretched. An empty drum has no load.
Mar 14, 2018 | Washing Machines
Door will not open if machine not emptied immediately cycle ends
This is an anti-flood protection, since water would flood the kitchen if you could open the door. If the machine shuts down for some fault and leaves the drum with water in, then it is advisable to drain the drum down via the small hose at the front of the machine. Simply remove the plug and empty into a large container until the drum is empty. You can then start to work out why the cycle ceased prematurely.
Mar 08, 2015 | Miele Washing Machines
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
"Drum cartridge is almost empty" I can't find a
If the drum cartridge is almost empty then soon the machine will stop printing altogether when the drum has reached its full life....you dont provide model so I would suggest you contact a local Muratec agent/ office and give them the model of the machine and they will know what drum you will require.
Jan 04, 2011 | Muratec Office Equipment & Supplies
Message: drum full of waste toner. replace drum cart. Does this mean it's time to replace the drum cartridge or do we just empty the overflow? Please e-mail april@happyvalleycc.org
Empty the container that holds the "waste" toner.
You may have to use the controls on the printer to say that you have emptied the container, because the printer is "estimating" (not actually "measuring") how full the container has become, based on the number of pages that have been printed.
May 29, 2010 | Dell 3010cn Laser Printer
Empty waste bucket on cannon 3050
If this is on a Canon NP3050 copier, the waste toner is stored in the drum unit. The developer unit needs to be released away from the drum unit before removing it (drum unit). There is a plastic lid to remove to empty waste toner. Use caution when emptying, it is easy to make a mess.
Nov 23, 2009 | Canon Office Equipment & Supplies
Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Feb 28, 2009 | Brother MFC 8220 All-In-One Laser Printer
It will not copy after I emptied the waste container.
There really isn't enough information given to give a proper solution. This copier has the drum light come on steady or flashing to indicate the waste toner needs to be removed. I don't know if you're a technician or not but lay people have emptied the toner cartridge instead of removing the drum, removing the cap on top of the drum, emptying the waste toner , replacing the cap on the drum, then putting the drum back into the copier. I've never had a copier keep the drum light on after doing this.
Let me know if you need more help.
Nov 18, 2008 | Canon NP 7130 Black and White Copier
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Hotpoint WMA74 Front Load Washer Logo
80 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
