Vornado Circulating Fan
Problem for Vornado Circulating Fan
Motor problem
By phong21 on Aug 04, 2008
I have an older vornado fan that i still love, but it has recently started making noise while in use. i disassembled the unit and it seems like the spinner portion is rubbing on the housing. does the unit just need some new grease or lubricant to fix the problem?
Comments:
Aug 05, 2008
- J,
Thanks for taking the time to respond with a fix. After posting this I actually could not wait and convinced myself the fan just needed some lubrication. I stopped at walmart for a $1.25 tube of general grease, went home and greased up the spinner plate. It works good as new now. These things really last!
Best Solution
posted on Aug 05, 2008
Helpful)
jmeredith
Rank: Guru
Rating: 86%, 105 votes
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
http://www.vornado.com/manuals/allcirc.pdf
J
Comments:
Aug 05, 2008
- hi,
you can try and oil it, unplug it and begin taking it apart, your destination is the fan motor, dust around the motor and I would recommend using regular automotive 10w30 motor oil on that motor, put some in a small bowl and use a small baster or equivalent and oil around both ends of the motor shaft(where it protrudes from the motor) behind the fan blades and behind it, look closely with a flashlight where the motor attatches to the back guard. try get some oil in there and within the motor housing to the inner bearing areas if possible. My guess is that its sealed from the factory, but you can try, those fans are the best on the market and have a long warranty, heres a link to the manual
J
Aug 05, 2008
- hi,
you may have to shim the motor shaft with a piece of tape or eqiuivalent, then reset if the fan assembly, it may be worn down or has lost its adhesion at the compression fitting there, maybe a shot of super glue, or even better JB WELD it
J
Aug 05, 2008
- hi again,
the motor has two bearings, make sure and get the back bearing as well as the front one.
J
Was this helpful?
Yes
No
Popular Solutions for Vornado Circulating Fan
Questions and Unsolved Problems for Vornado Circulating Fan
Do you recommend Vornado Circulating Fan?
Answer
Answer
Model 280ss fan has started miking noise when running
Answer
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've... (More)
Answer
How do I open Vornado fan (model EH1) so that I could clean fan blades?
Answer
I have a vornado fan on a pedistal that's about 13 years old. Have to twirl the blades manually to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vornado Circulating Fan:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
