Sounds like the lamp might have blown. Sometimes the projector can't tell if the lamp is blown, so the usual red indicator light doesn't show.
After the projector is on, if you push menu on the remote do you see anything? Maybe the brightness is just turned down all the way. If you see no menu when you push the menu button it's time to inspect the lamp.
Open up the projector and pull out the lamp. You'll probably need a screwdriver to remove the cover, and then another screwdriver to unscrew the lamp and pull it out. Be careful not to touch the bulb's insides. Is the lamp on the inside of the fixture bulbous, or cracked. Look closely.
