Question about Gateway T-6829h (5200 mAh)
I have a gateway P-6829H laptop p/n 1015734. My battery does not charge anymore and stuck at 2% capacity. I get the message "plugged in, not charging"
  • 90 Answers
This message means that you have over used your battery. The battery will no longer hold a charge and must be replaced. I would recommend purchasing a new battery.
Posted on Apr 04, 2011
Gateway battery only charges to 70 %
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Gateway Computers & Internet
Samsung N145 Plus battery charge failure
Sep 03, 2012 | Samsung Computers & Internet
I have a Dell Vostro 1520. I bought a replacement battery in october 2010 and it stopped charging at all in June 2011. they tested it at the battery store and said it was irreparable. So i bought a new...
Lithium batteries mustn't be fully discharged or it can loss the possibility to recharge it: only every 2-3 months you have to dischage it until the pc shuts down and then recharge to preserve its capacity. Is normal that in the battery remain some volts but ther's no sufficent ampere to make works the pc, listen if someone has different ideas but I think you've to buy another one.
Jul 09, 2011 | Dell Inspiron 1545 Notebook
I noticed that my charging status of my M-2623u laptop shows a "Plugged in, not charging" status. I turned off the system, took out the battery, waited 5 minutes, reinstalled the battery, and...
Similar topic on answers.microsoft.com below, may it would hlep:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Apr 25, 2011 | Gateway M2623u Laptop Charger...
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
My laptop has stopped charging when i click on the battery icon it says "15% available plugged in but not charging" as soon as pull the AC cord the laptop switches off. Any ideas
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 08, 2011 | Acer Aspire 5500 5570-2609 Laptop
My gateway M-7031U stops charging at 30%
Unfortunately your battery is probably shot. First though, try to run the battery down until the laptop dies. Now with the discharged battery, and the laptop powered off, plug it in and leave it off for a few hours. Power the laptop back on and check the charge level. Still at 30%? Then the battery is very likely just bad. Unfortunately, the cells in the battery just simply die for a number of reasons, and capacity is lost. This is why most manufactures will only warranty a battery for 1 year.
Take the battery out and write down the model number and the "MAh" or "Ah" number. The MAh number represents the capacity of the battery. The higher this number, the generally longer the laptop runs on battery. Go to http://gateway.shopbysystem.com/gateway-m-7301u-notebook-accessories.html and verify that this is your laptop model. This is a Gateway authorized reseller. Looks like they want $90 for a small battery. Take your battery model number and go to Amazon and look up the battery there. Make sure it's MAh number matches or exceeds what is on your battery. Usually you can get a replacement battery from Amazon for about $20 less than Gateway.
Oct 21, 2010 | Gateway M-7301u Notebook
Have a gateway M465-E with power issues. Low
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 26, 2009 | Gateway M465-E Notebook
Modem not found in hardware anymore
there should be a small cover on the bottom of the unit over the modem, if you can remove the modem and re-install. Make sure the computer is off and unplugged. with the battery removed B-4 you start this.
Mar 24, 2009 | Gateway Computers & Internet
Gateway T-6829h (5200 mAh) Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
