Question about Linksys Wireless-G Broadband Router
May i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
    Master:
  • 451 Answers
You need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
Posted on Mar 28, 2011
Thomson gateway tg585
yes i need my password or linksys wirless-g broadband router i need doe code ? pls give me now
Sep 03, 2013 | Linksys Wireless-G Broadband Router
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Cannot connect to wireless Broadband Router
Call linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
Since you're having problem in setting this router up, the best to way to set it up is by doing a mnual configuration and you dont need to use the setup CD that came with it, I'm suggesting you to call the linksys tech support and they will walk you through on the manual setup it will only take about 10 minutes this is the number 800-3267114.
Hope that helps.........
Aug 13, 2008 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Wireless G broadband router
Please go to www.linksys.com/download and download firmware version of your router. For manual upgrade call linksys at 18003267114 or check out other linksys numbers.
Oct 15, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
125 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
