JVC Dvd video recorder & video cassette recorder (DR-MV1S) Why do I get "disk erroe" on some rental disks? How do I fix this problem?
    Scholar:
  • 146 Answers
Are these discs very scratched up??
they usually are from the rental places
you cant fix anything if you are getting scratched discs
you might be able to open your player and very carefully clean the 'eye' of the player with a qtip and rubbing alcohol this might help so the laser has more strength
but it is more than likely the quality of the rentals you are getting
good luck - hope this helps a bit
Posted on Mar 28, 2011
Whenever I load a rental dvd, I get "Disk Error",
This unit has had problems playing dual layered dvds and since most newer are Dl try a older rental Movie and see if that works
Mar 28, 2011 | JVC DR-MV1S DVD Recorder/VCR
Tip
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Sep 24, 2008 | Philips DVP5140 DVD Player
Der / VCR... View all results for: "dvd recorder vcr combo brisbane"View now! JVC DR-MV1S DVD Recorder / VCR Combo Approx how much in Australia
When the unit was new in USA, it retailed for around $550USD which at the current foreign exchange rate is about $542 (approximate). According to one forum, many people are advising that you steer clear of this 2004/05 model! It doesn't last. They have had numerous problems with this model.
I personally would not recommend that anyone bother with this particular model at all. Buy a better brand (it does not have to be new or terribly expensive). JVC products over the past few years have been less than reliable.
Mar 05, 2011 | JVC DR-MV1S DVD Recorder/VCR
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
Jun 18, 2017 | JVC DR-MV1S DVD Recorder/VCR
Code to unlock zone
Mine says it is a region 4 DVD player, but yours could be different. But referring to mine, i have played DVDs from overseas, e.g USA and KOREA with no problem. Its a fantastic piece of equipment, the JVC DR-MV1S. =)
Sep 09, 2008 | JVC DR-MV1S DVD Recorder/VCR
Cooling fan stays on all night
You probably have set up one scart as being connected to 'sat' or sat controlled
(I cannot remember the exact setting)
If you do so, the recorder is controlled by the satreceiver, and is 'on' all the time.
Good luck (my DR M10 broke down yesterday - The drive does not recognise dvd-ram disks anymore :( )
Aug 06, 2008 | JVC DR-MV1S DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Jvc dr-mv1s video dvd recorder
switch the unit off at the plug and back on again.hey presto it opens again
Feb 24, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1S DVD Recorder / VCR... Problem
if you can actually reset the dvd/vcr recorder try the dvd menu...it should be under one of it's submenus
Jan 18, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
