Question about Sony Televison & Video
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
  • 2 more comments
  • zachbrogan Mar 28, 2011
    I have a multimeter if there are voltages I should check...
    So what do I do?
  • zachbrogan Mar 30, 2011
    If I unplug the inverter, the sound will come on for about a minute when I turn it on, then goes straight to solid red standby. So the double red is only when the illumination is plugged in. So what should I do?
  • zachbrogan Apr 01, 2011
    Is there any way to check if it is for sure faulty? I have a multimeter
    Brigadier General:
  • 8,909 Answers
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Posted on Mar 28, 2011
  • specialistel Mar 29, 2011
    The over current protection can be caused by almost anything but the favourites are the audio output stage and short circuit diodes on the secondary of the power supply coupled with but not so common, line output transformer problems.
    Be carefull, they bite!
  • specialistel Mar 30, 2011
    It is quite likely the invertor is faulty.
    I would order a replacement one.
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony KDL-40s4100 flashes and error code of 2 after about 7 seconds, then nothing. The backlight was on for about 2 seconds.
Have the same tv with the same problem. Changed the power board - no help. Next I changed the inverter board - no help. Only thing left is the LCD screen. I junked mine out. Hope I helped you out even if it wasn't what you wanted to hear.
Dec 10, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
1,019 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
