Question about Hobart Food Processors
Bought used Hobart Buffalo chopper, Model 8181-D. How do you remove the blades.
4 Suggested Answers
SOURCE: Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Posted on Jan 06, 2008
SOURCE: Need replacement part - S Blade/Chopper Blade
You can call Hamilton Beach Customer Service at 1-800-851-8900 from 8am to 6pm ET to order the S Blade. I called to get a price for my S Blade that broke on my 702R model food processor. They quoted me $15.99 plus tax. Now I am looking on the Internet for a cheaper price. Hope this helps.
Posted on Feb 24, 2009
SOURCE: how to remove and replace a hobart slicer blade
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Posted on Nov 03, 2009
I need replacement chopping blade. Help please
You should be able to do a search for your particular manufacturer and model food processor using one of the search engines. For example if you are looking for a Cuisinart model CH-4-DC chopper blade enter the search terms Cuisinart Model CH-4-DC chopper blade replacement in your search engine. Amazon is usually a pretty good place to start.
Mar 29, 2015 | Food Processors
New blade
If still interested in a replacement blade for the Ultimate Chopper, go to http://www.tvtimedirect.com.
Use the Quick Find option (upper right) - type in Ultimate Chopper and it will show their replacement listing for this item. Their phone # is 800.238.7119
Oct 11, 2009 | Ultimate Chopper Food Processor
How to remove and replace a hobart slicer blade model 2712
Sep 09, 2009 | Hobart Food Processors
Replacement parts for the "Power Chopper blender"
same problem too!
I have my chopping blade broke, I need the new one.
please email me (mamakoi_saja_yahoo.com) where I can order one.
Jan 27, 2009 | As Seen On TV Power Chopper PC4 Food...
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
How do you remove the blender blades from the ultimate chopper?
Press and hold down the center shaft of the blade assembly and lift the blades straight up. You can go here: http://www.ultimatechopper.com/chopper_ul_manual_eng.pdf for a downloadable pdf copy of the user's manual.
Jan 03, 2009 | Ultimate Chopper Food Processor
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Mar 07, 2008 | Hamilton Beach Chefprep 70700 Food...
Nov 16, 2007 | Ultimate Chopper Food Processor
Food Processors Logo
88 people viewed this question
Top Hobart Food Processors Experts
Are you a Hobart Food Processor Expert? Answer questions, earn points and help others
