Touch pad can't not function double click as enter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Check the double click speed in control panel mouse properties buttons
maybe its to fast
or check the mouse driver options to see if th tap is enabled
Posted on Mar 29, 2011
Activate/deactivate touchpad
FN or function key and the icon key that looks like a mouse or touch pad. That combination will activate and also deactivate this mouse or touch pad feature.
Hope this helps ya.
Nerd Tech Junkie - Will
Dec 04, 2016 | Computers & Internet
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
My mouse on my presario v2000 seems to be working when i move it using the touch pad, unfortunately when i doudle click nothing works - unless i left click the mouse pad. help? how do i get the touch pad...
I would verify that you have the compaq drivers installed for the mouse pad NOT the microsoft defaults alot of the time they add functionally like the double tap click and things like that. The link is
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=500746&prodTypeId=321957&prodSeriesId=432985&swLang=8&taskId=135&swEnvOID=228#11318
Its under input devices I selected windows XP I dunno your operating system but if your operating system is Windows xp that will work.
Like this if it worked for you. PLEASE!!!!
May 16, 2011 | HP Compaq Presario V2000 Notebook
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Jan 16, 2010 | HP Pavilion Dv3-1075us Notebook
Touchpad scroll is not working in my laptop lenovo 3000G430
download synaptics pointer device off the net its free.
Aug 14, 2009 | Computers & Internet
How do I set touchpad settings to inop touchpad when USB wireless mouse is plugged in
Some laptops have a Fn Key sequence to disable the touch pad. Look for the touch pad icon on your function keys (hand touching finger on a square). You can also go to the toucpad app by double clicking on the touch pad icon in the system tray and got to device properties to disable tapping - assuming issue is TPad interfering with typing
Jul 25, 2009 | Toshiba Satellite U305-S5097 Notebook
Touch pad - not double clicking for selection
Please run system restore but visit http:/www.hp.com go to drivers and download synaptic touch drivers again.
Good luck
May 19, 2009 | HP Compaq nc6000 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Sep 04, 2008 | Dell Latitude C610 Notebook
Touch pad
During startup press F2 and you will enter the bios setup utility. There you can change the optio of touc pad to off.
Be carefull while changing anything in the bios setup utility.
May 13, 2008 | Sony VAIO VGN-NR185ET Notebook PC - Wenge...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
