Question about Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor
My BW 325S pumps up to 245 it never done this before. gives me real high reading different then the doc.
    Brigadier General:
  • 4,736 Answers
The unit may need to be re-calibrated. In which case, you need to return it to the manufacturer. Most will do it for little or no charge, as long as you have your Proof of Purchase.
Posted on Mar 28, 2011
What does high CPU usage mean?
Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
Mar 06, 2015 | Computers & Internet
If I wont to go up 10mm on a 235x35x19 tyre what size do i go to
Either 245/35/19 or 245/30/19. With the 245/35 your speedometer will read slightly slower than the actual speed, 245/30 will read slightly faster than real speed.
Jan 26, 2014 | Silly Ricer, Stickers Wont Make Your Car...
Sand in fisher and paykel washing machine error 245
This is a pump stall error code. Remove the pump from bottom of washer. make sure nothing is clogging pump. If problem persists replace pump.
Oct 27, 2012 | Fisher Paykel Washing Machines
How do I backwash my sanddollar pool filter
Shut the pump off, then push down on the backwash (BW) handel turn it clockwise 180 degrees to BW and start pump again. Run pump till water coming from BW pipe runs from cloudy to clear. Shut the pump off and pushing down on the BW handel again turn it 180 degrees to filter and start pump again.
Oct 27, 2010 | Pentair Sand Dollar 19" Filter with 1 Hp...
Can I place 4 215/75/R15 Jeep Sport tires on a Jeep Grand Cherokee that has 245/70/R15 on it now? Will the smaller tires work without problems?
The 215's will give you less ground clearance and may affect your speedometer accuracy a bit. Other than that and that it may look a bit different, there should be no real problem.
Sep 02, 2010 | Jeep Grand Cherokee Cars & Trucks
My 1996 yukon came with p265/75r16 tires. could i put 245/75r16 tires on it and what kind of problems would i have if i did?
Should have no problems at all. 245 is just 2 cm ( about an inch ) narrower than a 265. Overall diameter will be slightly smaller as well which will affect your speedometer but not too much. Spedo will read slightly higher than actual speed.
Nov 07, 2009 | 1996 GMC Yukon
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
BMW different tyre profile front and back
Yes it is, you wont notice any differens except the "look", your car wont look so cool as whit the 275 tires.
Dec 05, 2008 | 1996 BMW 7 Series
Take case off of samsung 245 bw
it is very simple just face the screen twords you and lay on a soft surface facing screen down on it and insert your fingers between the gap on rear side and slightly pull the outer cover and do it with little force. Do not put any hard tool. it would damage the shape. always remember start from top upper rearside gape only.
this way you can unlock 3-4 locks and do it simultaniously and once all upper side locks are out slight try with left and right.bottom will release you can use tool carefully once some locks are out.
Rameshwar Dahiya
Dec 02, 2007 | Samsung SyncMaster 245BW Monitor
Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor Logo
124 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
