Question about Hoover Vacuums
My hoover keeps tripping the house fuse everytime i plug it in
  • 484 Answers
The fuse in the plug must have blown or you have a broken wire along the cord length somewhere. Is anything wet?
Posted on Mar 28, 2011
Why does my hoover curve keep tripping out after 5 minutes
you have a blockage and the motor is overheating ,look for a blockage in one of the pipes
Dec 12, 2014 | Hoover Vacuums
Nilfisk hoover will not switch on
Start with the basics, check for a reset button on the motor housing, make sure the circuit that the appliance is plugged into not a gfi circuit
thats been tripped. Keep in mind that when working with any electrical
-know your kimits!
Aug 16, 2014 | Nilfisk Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Fuse keeps tripping
check the power cable for splits or brakes
May 08, 2013 | Hoover Vacuums
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Hoover upright has stopped working and tripped the circuit breaker. Where is the fuse located on the hoover ?
Most Hoover uprights do not have fuse. Some canisters doe but it is a thermal shutoff. When the vac overheats and cools down it restarts on its own.
You very likly have motor damage, but if lucky you could have an obstruction in the fan causing a jam. Do not attempt to run again.Lift the lid off the vac and see if the drive shaft for the belt will turn. If not motor will need to be removed and fan housing and intake area inspected. If the motor shaft turns and you hear scratching or clicking, the carbon brushes are likely damaged often requiring a replacement motor. If the fan is jammed you will need to dismantle the fan housing. Remove the two motor clamps and there will be four screws on the side of the housing to release the fan cover. The fan should rotate freely in your hand.
Sep 13, 2009 | Vacuums
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Henry Hoover throwing trip switch in house
Sounds more likely to be the switch than the motor, especially if it is the model with the top switch rather than the side "rocker" switch. If you are in the UK, speak to the technical people at www.a1cleaningsupplies.co.uk they can post a replacement. Otherwise outside or even within the UK you can contact the manufacturers technical people. Website is www.numatic.com
May 25, 2009 | Numatic Henry Bagged Canister Vacuum
Vacuums Logo
332 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
